Results 1 to 25 of 37
Thread: E21 350 sbc swap
    Jan 2006
    MA
    Integra(dead), '89 325is
    E21 350 sbc swap
    So I bought a e21 a few weeks back with no drivetrain.
    The car is fairly good for a car that’s been in New England for the last 10 years
    It came with a m50 and a Getrag transmission.
    After looking over everything that the car came with we decided that for the amount of odds and ends needed to do the swap, especially the e34 oil pan, it would be easier to use some thing we already had.
    So we did a thing
    After test fitting the new engine, it looks like it will actually fit. It has a turbo 350 trans on it now that we’ll switch to a t5 which should save some room.
    -Tony
    1989 325is
    St. Louis, Missouri
    68,74,75,77,80 race cars
    Well that explains why I didn’t get a response from the seller (the ad is still running in the Boston CL). Congrats on the purchase Tony. I remember that car when it was new here in St. Louis, I was going to bring it back here for a 3.5 M30 conversion, oh well.
    All the best.-Bill
    1968 IMSA RS 2002
    1974 SCCA ITA 2002 tii
    1975 Miller & Norburn IMSA RS 320
    1977 SCCA ITB 320
    1980 ETCC/STT/Div2 320/6/3.5 turbo
    Jan 2006
    MA
    Quote Originally Posted by glashaus View Post
    All the best.-Bill
    1968 IMSA RS 2002
    1977 SCCA ITB 320
    Yeah I see it up there all the time. Always looking for a cheap e30.
    -Tony
    1989 325is
    Oct 2015
    RI
    1983 320is S52/2003 VR6T
    going to very front heavy but should be fun
    Jan 2006
    MA
    Quote Originally Posted by pofo View Post
    I wanna say it’s an additional 100lb over the m50.
    I have no idea what the spring rate is on the coilovers but it seems to sit at a decent height.
    -Tony
    1989 325is
    Dec 2017
    Berkshire County, MA
    80 E21 Euro, 85 E30 Euro
    Oh boy, here we go...
    I'm curious what kind of hacking is going to have to go on to get that engine to rest comfortably on the existing crossmember.
    Either way this is certainly an unusual E21 build, and I applaud the audacity of the project. Most people don't dare go heavier and bigger than an M50/M52/S52.
    Good luck to ya
    Jan 2006
    MA
    Actually once we switch the pan out it’s should sit in perfectly.
    As it sits now the sump is a little front of center on the crossmember. So when we switch pans we should be able to move it back another inch
    -Tony
    1989 325is
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    Remote mount reservoirs for the brakes down the line?
    -John
    Jan 2006
    MA
    Realistically this will never be a super competitive track car, not without spending a stupid amount of money and time. As it sits now we’ll have to remove the booster and reservoir to get the engine in with the other head installed.
    Considering just ditching the booster but with the extra weight in the front I think that’d be a mistake.
    -Tony
    1989 325is
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    There were remote mount boosters that went in later generations, you might consider those. Since the battery is already out that's a great spot for it.
    -John
    Jan 2006
    MA
    Quote Originally Posted by Somjuan View Post
    I’ll have to look into that once I get the driveline squared away.
    The battery is mounted in a strut tower brace in the rear.
    -Tony
    1989 325is
    Oct 2015
    RI
    Most people with E30's and E36's use left hand drive boosters when doing V8 swaps.
    monterey, ca.
    e21, e30 m3. e46 330ci
    Quote Originally Posted by diesel1245 View Post
    just ditch the V8, it's a stupid idea, plain and simple!
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
    Jan 2006
    MA
    Quote Originally Posted by Tom D View Post
    That’s cool.
    -Tony
    1989 325is
    Jun 2015
    San Antonio, Tx
    1977 320i
    Interesting Project! Once Sorted it should be a blast on the street, and with coilovers you will be able to adjust the front spring rate to get decent enough handling (may also need a thicker front sway bar). 1sh Gen VW fox's have manual Master cylinders that are properly sized for the stock brakes and may be viable.
    Love the wheels, if you decide they are not for you... please let me know.
    Jan 2006
    MA
    Quote Originally Posted by WantingAfunE21 View Post
    I’ll look into the manual booster
    As for the wheels they’re drag dr20s. Fairly cheap for the set.
    -Tony
    1989 325is
    Mar 2014
    Sun Prairie, WI
    M42 swap, turbo imminent
    Don't know about an M50, but an M42 is probably heavier than an M10, and an LS is lighter than a small block, and the difference between an M42 and an LS is about 180 pounds.
    Also keep in mind that the rear of an e21 gains a ton of camber when the rear squats under acceleration. If your goal is to go fast, you'll be very disappointed. If you don't care about handling or straight-line performance, but want to be able to get a lot of wheel spin in every gear you'll be satisfied with the results.
    Dec 2007
    Atlanta, GA
    M-Z3,535i, 320,Vette
    The Gen 1 SBC with cast iron block & heads weighs in around 585lbs fully dressed....
    The M42 around 350 and M50 around 430lbs.
    IIRC the M10 comes in around 280...
    That's a BIG wight difference over the front wheels.
    If you do go with the SBC- go with the short waterpump and pulleys (AKA the corvette waterpump)- you'll need the clearance.
    For the oil pan- look at a 62-67 Chevy II oil pan- should work
    As far as the brakes- if you do away with the booster you'll need to go with a smaller bore or an ingenious set up like this to get the extra ummmp needed to kick the rock hard pedal-
    Even a M70 V12 will fit... just the devil in the details!!!
    monterey, ca.
    Quote Originally Posted by Richard454 View Post
    The M42 (weighs) around 350 and M50 around 430lbs. the M10 comes in around 280...
    while i agree with you that a M42 is less then a M50 and they're both lighter then a chevy V8, i don't agree that engine weights alone are as important as the engine/trans weights (you're not going to bolt a lightweight G242 behind a iron block V8). also where that weight is placed over the axle has a lot to do with the handling. so a shorter engine like a V8 will have less of a weight effect then that a longer block I6 then initially suspected based solely on engine weights.
    the photo above shows the M42 with a heaver G250 trans and ac/power steering at 427 lbs. i weighed an 1981 m10 last year complete with a G245 and ac, it was 450 lbs.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    Jan 2006
    MA
    Update:
    We diced to ditch the small block in favor of using it for another project.
    Instead, I was able to track down the original engine that came in the car
    It was built by another member here a few years back and passed around until it ended up here.
    -Tony
    1989 325is
    Jan 2006
    MA
    Side note:
    What the fuck is this?
    -Tony
    1989 325is
    Aug 2001
    NC
    E30M3,318is,318i,E21320
    The dangling switch is the factory fog switch.
    I like where they tapped the oil feed for the turbo. Great spot and where I chose to tap for my oil pressure gauge line. Motor seems familiar but I can't place who's it was. Bet it makes plenty.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
    Jan 2006
    MA
    Quote Originally Posted by autox320 View Post
    It was built by bionicbelly.
    I found him on Facebook and he gave me a rundown on the engine.
    “A basic rundown is new pistons, rebuilt head with proper valve seats, MLS head gasket, new timing chain, guides, crank was not machined, but new bearings, and tolerances were perfect, 2.0L block, 1.8 head, the manifold was from boost brothers (probably not around anymore) the coil pack is of a ford escort, as is the timing wheel and trigger. The turbo I put on there was a garrett T3. I think it was off a volvo (twin scroll) I rebuilt it with new seals and bearings. Not sure if that is still what was on there or not. Seems like I remeber one of the owners switching it out fo something bigger. (I don't like lag)”
    I’m pretty certain the turbo was swapped out since he had it.
    -Tony
    1989 325is
    Corona California
    79 320/6 81320i 65malibu
    V8's into an E21s are not a new idea.
    Just depends on what you want and how much work you want to do.
    Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
    Aug 2001
    NC
    Legit. Yeah T3 all the way man I'm not one for laggy boosted motors as a NA guy. T3/T4 hybrid makes insane power but has lag IMO true T3 on a 2L is perfect in my book.
    Nice build man so when is the date the project of marrying the motor into the chassis and run it?
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
  1. 85 325 Conversion to 350 SBC 700R4
    By BlownShovel in forum Engine Conversions
    Last Post: 07-28-2020, 12:21 AM
  2. 1975 BMW 2002 E21 1.8L Swap LI, NY
    By Le Nitro in forum New York / New Jersey / Connecticut
    Last Post: 02-04-2008, 10:46 PM
  3. e30 323, e21 323 motor-swap?
    By vibranthenarot in forum 1975 - 1983 (E21)
    Last Post: 11-08-2007, 10:18 PM
  4. ***e21 possible engine swaps***
    By gol10dr1 in forum 1975 - 1983 (E21)
    Last Post: 11-08-2006, 01:11 PM
  5. e21 320i motor swap?
    By buhx2 in forum 2002
    Last Post: 07-20-2006, 03:11 AM
