Results 1 to 5 of 5
Thread: E36 325 1992 | radio wiring | What wires are these?
    May 2018
    Amsterdam (EU)
    325i '92, Polo 6R, XJ6S3
    Hello,
    These wires are in a stock connector I assume, but left from my hand, there are a few thick wires (in the round circle). These are positive (red) and ground (brown). What do they do?
    In my hand I have got the speakers and power sockets / wires.
    I'm confused what these wires should do!?
    Thanks for your help, greeting from Amsterdam, Holland!
    Verstuurd vanaf mijn SM-G950F met Tapatalk
    Arklahoma
    '94 325i, '97 528i
    That doesn't look like stock wiring . The Browns may be the speaker grounds running to the amplifier, but no clue on the red wires.
    I'd Google the e36 radio connector pinout and see where they connect.
    Hope this helps!
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Apr 2017
    NJ
    1995 318ic
    Thats definitely an aftermarket harness. My best guess would be the reds are your RR, RF, LR & LF positives and the greys your negatives, remote, power, ground, etc?
    The Netherlands
    DE-spec E36 328i/M3 cab
    You can clearly see the factory plug, with a BMW-to-DIN adapter cable on it.
    Unplug the adapter harness and there you go, factory connector. Plug in an OEM radio and be done with.
    Or get a new adapter cable if you insist on running a modern headunit that uses these standard DIN connectors.
    IG:
    Aug 2009
    sunnyvale CA
    325is
    The factory wires looked cut and a new connector installed
    You can trace the original use and connect a new radio and connector or ask the previous owner what radio was removed
  1. Replacing e36 vert aftermarket radio with CD43 - wiring help/analysis
    By JTHiggins in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-28-2011, 07:17 PM
  2. E36 WTB e36 325 or e34 525 obd1 engine wiring harnness
    By bmwwindout in forum BMW Parts Wanted
    Last Post: 06-22-2010, 10:53 PM
  3. e36 325 can i use an auto engine wiring harness on a manual 5 speed both out of a 93
    By t25bimmer in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-20-2003, 09:44 AM
  4. engine wiring harness e36 325 ? please respond
    Last Post: 03-19-2003, 07:45 PM
  5. will a e36 325 automatic engine wiring harness work on a manual tranny?
    By t25bimmer in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 03-19-2003, 07:24 PM
