Results 1 to 4 of 4
Thread: Power steering coolers
    Nov 2012
    Atlanta, GA
    1995 BMW M3 Coupe
    Let's talk about power steering coolers.
    Where to mount, how to mount, and which style.
    I need to get my power steering fluid temps down. My set up is likely different from everyone else, but right now, my headers/crossover/turbo is heating up my power steering fluid on runs.
    I know its heating up and boiling, because at the end of every run, There will be air in the lines (whining ps pump) and ill let it cool down and it'll be fine. I also moved and heat shielded the ps lines away from the heat source, and it lasts longer now (without boiling), but still not long enough. so, I need a cooler.
    my current thinking is a tube and fin style cooler to completely replace the stock cooler, in the same location (front of ps rack). But I would like to hear some other ideas.
    Particularly, the benefits of the finned cylinder designs.
    Also, I have heard of some mushy-ness caused by putting a PS cooler between a LS1 pump and BMW rack, can anyone confirm? I am slightly over driving my pump, so I may have a little increased pressure anyway....
    TIA!
    fairfax,va, usa
    2 E30s and a maxima
    I had a PS cooler on my bmw rack with my LS2. It felt 100% stock on my E30. I'm a fan of those autozone specials where it's just a tube + fins. Placement is really anywhere that gets air. I try to mount them on or behind something solid so it won't go flying in a crash. That's it. No reason not to do it. It's barely any additional weight.
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    JZ here running a koyorad 15row cooler with a chasebays reservoir, works perfectly, feels stock.
    instagram @andyitslit
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I hated my LS pump with bmw rack either way, but I also had real bad boiling problems. I installed a summit brand heat sink syle cooler in front of the rack, and somehow it was impossible to bleed and made the problem worse. Switched to Amsoil PS (higher BP) and it helped enough to get by. Now I run an E46 pump with Amsoil and it doesn't become an issue until 10+ hotlaps of a mile long track
  1. Power steering cooler - necessary?
    By 5mall5nail5 in forum Forced Induction
    Last Post: 01-07-2008, 02:47 PM
  2. M3 Power steering cooler fit in MZ3?
    By who8mylunch in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-05-2005, 08:09 PM
  3. aftermarket power steering cooler
    By Drifto in forum 1992 - 1999 M3 (E36)
    Last Post: 06-27-2003, 01:48 AM
  4. power steering cooler part number
    By cos M3/4 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-21-2003, 04:49 PM
  5. WTB power steering cooler
    By cos M3/4 in forum BMW Parts Wanted
    Last Post: 05-21-2003, 04:43 PM
