RM European Auto Parts
Results 1 to 10 of 10
Thread: 2003 325i A/C system failure
    Jun 2018
    Cincinnati
    2003 BMW 325i
    A/C has been out since I bought the car. It’s getting so hot here that I almost can’t drive it.
    Anyway, the compressor spins, and when the A/C is enabled you can feel it kick on but no cold air. I took pressure measurements of the high and low side of my system. On the valve closer to the windshield I’m getting 63psi, and the valve closer to the bumper reads 59psi. The system has held pressure for weeks, so it’s not a leak. Could this be a problem with my compressor?
    Northern VA
    97 M3/4/5; 04 M3 6M
    When you say it's been "out," do you mean it's anemic or just plain dead? Is the aux fan working? Have you tested the relays? On mine, just pulling the fan relay and testing it, as well as jumping the panel connectors (use a fused jumper! 30 Ω?), returned it to functioning order. Now I have a spare fan (for an E36).
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    If, truly, you've connected to the high side AND the low side, at the same time, and the compressor clutch is turning, and the gauges read 59 low side and 63 high side. Then, first, you need to evacuate, vacuum, and refill the system with EXACTLY the correct amount of R134a. (If I'm not mistaken, that's 1;63 lbs, on your car. Then you'll read the gauges again. If the system still shows exactly the same (which I doubt), then you need to replace the compressor, the receiver/dryer, and the expansion valve.
    If you do not have a proper set of gauges and a/c machine, take the car to a pro.
    Chris Powell
    BMWCCA 274412
    Jun 2018
    Cincinnati
    2003 BMW 325i
    This test was done without the compressor on. Will test again within a day with the compressor running and post results
    Jun 2002
    E39M5, E500 4WD
    You don't test an A/C system with the compressor off. What would you be testing?
    Chris Powell
    BMWCCA 274412
    May 2009
    MD
    2001 330i
    Is the fan running? Can you feel air coming through the vents? As you increase the fan speed can you feel more and more air coming through the vents?
    Jun 2018
    Cincinnati
    2003 BMW 325i
    The blower is running fine. Will test pressures soon. Thanks for the replies.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Does the electric fan that either sits in front of the radiator (auto transmission) or between the radiator and the engine (manual transmission) come on?
    Jun 2018
    Cincinnati
    2003 BMW 325i
    OK I have the pressures from the high and low side of the AC system, while the compressor was engaged. Low side is 30psi, high side is 85psi. Yes the fan does come on, my car is manual.
    Jun 2002
    E39M5, E500 4WD
    IF you have the correct 1.63 pounds of R134a refrigerant in the system, your compressor is bad. 30 psi is right; high side should be ~175 to 250, depending on ambient temp.
    Chris Powell
    BMWCCA 274412
  1. 2003 325i - How Often Do You Replace Your Coolant System and Belts?
    By rollingdirty1 in forum 1999 - 2006 (E46)
    Last Post: 07-03-2012, 11:31 PM
  2. 2003 325i e46 Cluster Gauge Failures
    By gaslane in forum 1999 - 2006 (E46)
    Last Post: 12-11-2011, 07:27 PM
  3. Upgrade my 2003 325i e46 exshaust system
    By los13 in forum 1999 - 2006 (E46)
    Last Post: 12-03-2009, 02:44 PM
  4. feeler: 2003 325i rims
    By krnbimmafrik in forum Wheels and Tires
    Last Post: 09-24-2003, 10:06 PM
  5. Just Purchaged 2003 325i -automat-
    By Vishal in forum 1999 - 2006 (E46)
    Last Post: 09-14-2003, 04:42 PM
