Results 1 to 14 of 14
Thread: Rotor Screw Won't Budge And Stripped!
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Hi all, 1995 525i 5SPD 278k
    I attempted to replace my rear driver side rotor and pads but..., the darn screw that holds the rotor in place is rusted on and stripped! I blasted it with Liquid Wrench, heated it up, tried to drill a hole in the bolt, and used extractors (won't grip the bolt). Is there a trick in getting that little bolt out during times like this?
    Thanks in advance!
    Kirkland, WA
    2006 Toyota Tundra
    Just keep drilling. The head will pop off eventually
    May 2017
    Perth, Western Australia
    09/90 E34 525i (M50)
    Yeah, by now drilling the head is your only option I guess.
    Next time use an impact after soaking for a day in penetrant. Don't even need a battery or air impact, just a hammer style impact screwdriver helps with these jobs (as well as a mapp torch)
    Zionsville, IN
    93 740i, 84 533i
    Drill it out enough and hit the back side of the rotor with a BFH. I have run about 100,000 miles with one of mine drilled out and not used.
    Black on Black 740i - 10/92 build date, 225,000 miles.
    Delphin on Cherry 533i - 4/84 build date, 136,000 miles
    Black on Black 328i - 3/96 build date, 185,000 miles - Sold
    2008 Porsche Cayenne GTS
    Oldham UK
    '00 330i Sprt '92 525i
    For such a small screw, they can cause a lot of grief. Try giving the screw head a couple of whacks with a hammer and chisel. Then try to rotate it using the same tools. If that fails, drill the head off as suggested above. Once the rotor is off, you may be able to get a pair of small vice grips on what remains of the screw and rotate it.
    Nov 2017
    Grand Haven, MI
    1990 535i 428k miles
    Since i was replacing the rotor i didn’t mind doing thing. But i took my Dremel and cut a deep slot into the screw and stuck a flathead socket into it.
    Moderator and Owner of the Subreddit r/E34
    Oct 2008
    Denver
    '91 M5
    I had the same problem the other month and I took Ross's advice of just whacking the back of the rotor with a hammer a few times and it came right off, taking the head of the screw with it. I would have ear pro on when doing it.
    Current Fleet:
    E34 1991 M5 Macaoblau on Complete (ruined)Leather Champagne - http://forums.bimmerforums.com/forum....php?t=1705166
    Past:
    E34 1989 535i 5-Speed AlpineweissII on Natur - Parted
    E34 1992 525i 5-Speed Islandgrun on Pergament - Parted
    E34 1995 540i 6-Speed ShwarzII on Shwarz - Sold to Sneezy.
    E34 1995 525i 5-Speed Calypso Red on Parchment - http://forums.bimmerforums.com/forum....php?t=1748143 - Sold locally.
    E39 1998 528i 5-Speed Black on Black - Sold locally.
    E34​ 1993 M5 Alpinweiss on Black - http://forums.bimmerforums.com/forum...lpinweissII-M5 - Parted
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    I really must sound like a broken record by now... See my comment in your previous thread about how to drill it, followed by using anti-seize to prevent this from recurring.
    Also, the only reason that bolt exists is to assist in wheel installation by lining up the bolt holes. It doesn't provide any meaningful clamping force; the lug bolts are what actually keeps the rotor in place on the hub. So leaving it off is an option, especially with a stud conversion, or if you do use it, there's no need to torque it any higher than for it not to fall out when a wheel is removed.
    Denver, CO, USA
    93 M5 88 M3 14 i3
    This. Always apply a small dab of anti seize guys.
    -Greg
    Oct 2003
    Seattle
    99 M3
    FYI -ECS sells a SS replacement.…and use anti-seize.
    NW suburban Chicago
    hiss by my window
    Replacing the rotor?
    Get a big hammer and hit it HARD from behind where the caliper would sit with the bolt positioned at that same position on the clock. The rotors are cast hence somewhat brittle, and the metal under the head of the retaining bolt is thin, a good hit will break it out. With the rotor off you'll have good access to the remains of the bolt which you can grip with a locking pliers.
    Best to put one lug bolt in a few turns to retain the rotor when it lets go and, again, anti seize paste is your(or the next guy's) friend.
    Apr 2014
    PA
    I have removed a few by cutting a straight slot in them and turning them out.
    "Helicopters: 10,0000 pieces of metal fatigue rotating around an oil leak."
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Thank you all for the advice. I will smack it from behind. If that doesn't work, I'll grab the grinder and grind a slit in the middle of the bolt, then turn with a flat head. Since I am replacing the rotor, there's no worry if I grind a slit on the rotor along with the bolt. Thank you all! Much appreciated..
    moroza's Avatar
    BFE
    E34T
    New rotor, don't care about the old? In that case, put on safety glasses and bash the living flick out of it while thinking of somebody you don't like (perhaps the chucklehead who forgot anti-seize on that screw and your wheel lug bolt); get some stress out while you're at it
  1. Help! Stripped rotor screw
    By Tnarkowicz in forum 1976 - 1989 (E24)
    Last Post: 10-06-2012, 10:30 PM
  2. Rotors nuts won't budge/stripped, any ideas?
    By 328iFun in forum 1991 - 1999 (E36)
    Last Post: 11-03-2011, 12:20 AM
  3. ARGH Brake rotor screw stripped!
    By CJ in forum 1992 - 1999 M3 (E36)
    Last Post: 01-26-2003, 10:36 PM
  4. Stripped Brake rotor screw
    By BimmerToad in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-31-2002, 07:03 PM
