FS - $8000--Rare 2003 e39 540MSPORT #861/1265 - 1/1265 imported in the USA and 1/3000 produced globally this is the final last year of the e39 and its a 540MSPORT - the most desirable unicorn e39-Has an original 36K mile engine from another 540MSPORT-RUNS STRONG- has a CUSTOM tune as well--- there are 190k on the chassis MUCH MUCH maintenance has already been done to this car at great expense- has an M5 working cluster !!! in the last 10K or less she has replaced and or improved over stock components such as water pump-alternator-motor mounts-eibach front & rear sway bars- spec racing custom flywheel and stage 2+ clutch- NEW starter- NEW fuel filter- NEW auxiliary fan- BC RACING COILS front and rear with camber plates- new battery- new front end control arms and related components- ROGUE STUDDS- DINAN STRUT BAR- frint and rear eibach sway bsrs - BEAST MASTER BRACKETS - NEW ZIONSVILLE custom radiator with ELECTRIC FAN- NEW custom front BBK using WILDWOOD AREO 6 calipers ! 3 sets of wheels- Wheeks are APEX EC7 RIMS - 595 RSR TIRES IN FRONT RE1's I rear 265's fronts- 285's rears- BMW M5 REAR LSD 3:15~M5 driveshaft ~Rogue Octane SSK-Dinan carbon fiber intake~ CUSTOM exhaust- M60 manifold- M5 cluster everything works--interior is better than fair condition I would say a 8 out 10- this is not a show car but a street legal daily driver- car handles like a go cart ready for track work and still drivable on the street- serious inquires only please--CLEAN TITLE-- and easily passes emissions EVERYTHING WORKS !!!!
THIS IS A HIGHLY DESIRABLE/MODIFIED MACHINE! THE CUSTOM FLYWHEEL & CLUCTH ALONE ARE $2000, THE COIL OVERS AND SUSPENSION WITH LABOR WERE OVER $2000, THE CUSTOM BIG BRAKES WERE OVER $3000, THE CUSTOM RADIATOR AND ELECTRIC FAN WERE OVER $1300, THE DAILY WHEELS APEX WITH TIRES OVER $2000, THE A1 HEADERS AND CUSTOM EXHAAUST OVER $2000, CUSTOM INTAKE AND CAI OVER $600, THE 36K MILE ENGINE PRICELESS! race wheels ENKIE 18x10 square wIth CONTINENTAL SLICKS 275 square are are extra nIt Included In sale !!!! BMW CCA MEMBER !!!!
2003 540MSPORT #861/1265 -GF71249 .Black Sapphire Metallic/Sandbeige.Dinan intake~M60 manifold
Spec racing stage 2+ clutch and custom light flywheel .M5 rear LSD 3:15~M5 driveshaft ~Rogue Octane SSK
36K ENGINE SWAP!!!.~Rogue thrust arm bushings~Rogue studds~Dinan strut bar
EIBACH front/rear sway bars with BEASTPOWER brackets~CDV delete~Redline fluids/Racing blue Ate~ APEX EC7 RIMS SQUARE 18 x 10's~M Pararallel rims 9.5 all around~285 30 18 rears~265 35 18 fronts~ENKIE 18x10's square with Continental Slicks 275's square~RE 11's, 595 RSR's~BC racing coil overs 8k/6K~Steel braided brake lines~Powder Coated valve covers-A1 headers 100 cell cats, performance resonator and 4”cross tips, CUSTOM BBK - MASSIVE HATS AND BRACKETS - AERO-6 WILDWOOD-, ANODIZED CALIPERS STAINLESS STEEL PISTONS THERMAL TREATED, CUSTOM WILDWOOD ROTORS 14.50”
