RM European Auto Parts
Results 1 to 25 of 28
Thread: Can't find coolant leak
    Mar 2018
    Ohio
    2001 BMW 325xi, e46, m54
    I did HG job over the last couple months.
    Had heads surfaced and pressure tested.
    Replaced radiator with cheap aftermarket.
    New t stat
    New coolant pipes
    1 new heater core hose
    New hose that goes from coolant pipe to expansion tank
    New (cheap) water pump
    Have not replaced expansion tank
    Just got new cap, but car hasn't been started since.
    Only things left to replace on cooling system is
    the hose that goes from coolant pipe to heater valve
    Lower radiator hose+sensor
    Heater return hose
    Expansion tank
    Isn't there a coolant sensor on the block or head?
    So when I drive I lose coolant. No steam from exhaust. No oil or combustion smell in coolant. Just changed oil, no coolant in there either... I drove about 4 miles the other day after filling and bleeding the system twice, it did not begin to overheat but when I got out, I noticed about a cup of coolant running out from under the car. I looked under there and it was dripping off of the (subframe?) bar that sits between the engine and transmission.
    I lost enough coolant to think that it would at least be a visible leak... I removed the intake manifold and did a pressure test on the system. I turned the key on and put the heater on to open the system, and I pumped it to 25psi. After about 10 min it dropped down to 19 and stayed there. Wasn't going below 19...
    No visible leaks no drips or anything.... Wtf. I figured if it was leaking bad enough to pour a cup out on the ground after engine is off then I should be able to see something with 25psi on it, but no...
    Any suggestions? I really thought because of the location that it would be the hose that connects the rear heater pipe to the heater valve, but it seems dry...
    Gonna get a leak down tester today too so I'll post results of that soon
    NW suburban Chicago
    hiss by my window
    Could be boiling off hot parts before enough collects to drip. Look for staining from the coolant at all the connections, cap, gaskets, etc.
    If it's going into the combustion chambers the spark plugs will show, the effected cylinders will have abnormally clean plugs. Fingers crossed for you.
    Jul 2005
    Indianapolis, USA
    1993 318i Touring
    The easiest DIY way to find a coolant leak is go drive the car and get it good and warmed up.
    Shut the engine off. LEAVE THE HOOD DOWN.
    Wait 5 minutes.
    Lift hood and look for the leak. 5 minutes after shutdown is the time when the engine is hottest and the pressures are also the highest. That's when the leaks show up.
    Mar 2018
    Ohio
    After a quick drive, I can see the drip coming right below the exhaust. There is even steam coming off the exhaust pipes. I put uv dye in the system and directly below that subframe bar there is a baseball sized puddle of green dye. I looked at the heater core hoses with the UV light and they are clean.... Gonna take the intake manifold off again tomorrow morning and see if there is dye anywhere
    But I do believe it's an external leak because it is puddling on the ground below the car.
    I pulled plugs a couple days ago and they were all blackish. Not really clean
    There's nothing on the far right side of the engine that can leak onto or around the exhaust except the head gasket. There's no hoses over there.
    Mar 2018
    Ohio
    So is it possible that the water jacket part in the hg blew and is leaking outside of the engine and not leaking internally?
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by Shawnk111 View Post
    Yep. Corrosion or overly aggressive cleaning of the block surface(whiz wheel leaves a divot) on the block or head.
    Dare I say it: this might be helped with something in a bottle
    ducking for cover now..............
    Mar 2018
    Ohio
    Dang... I'll pull the intake off again tomorrow and see if I can see any dye. If not I guess I'll put a bottle of stop leak in
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    WAIT.
    Don't disassemble until you find the leak.
    I think I asked you this on another of your threads: Did you replace the two plastic coolant pipes from the front of the head to the back and side of the motor?
    Don't take it apart until you know what you're replacing.
    EDIT: STOP LEAK ??? GTF outa here. If you put that crap in your cooling system, don't come looking for help here! You will have officially crossed over to an entirely different forum, the title of which is not flattering.
    Chris Powell
    BMWCCA 274412
    Northern VA
    97 M3/4/5; 04 M3 6M
    I agree with Chris, but after a while I think you will need to redo the head gasket. I chased a leak for over 6 mos. Finally just bit the bullet and brought the head to a machine shop. 8-9 thou got shaved, warped at the corners enough to leak overboard (as you suspect), would see drips hanging from the subframe, absolutely no other sign of the leaking fluid.
    The other curious thing about my condition, which I documented elsewhere in this forum, was that the expansion tank would always show the fluid at the "kalt" line when...even the morning after it overheated!...once when it was 20° out.
    Mar 2018
    Ohio
    Yes coolant pipes were replaced. I removed the intake again this morning and found the leak coming from the rear intake side corner of the heads. I paid a shop to machine them to a flat surface when I did the job. And I used a reputable brand gasket. Should I contact the shop and see if they will surface it again? They took of 0.015 the first time.
    NW suburban Chicago
    hiss by my window
    WAIT.
    Yeah, that's what I meant if the HG is weeping externally. OP says the head was decked, so that leaves the block or a shite gasket. Either way another big job.
    A million Cadillacs can't be wrong
    Jun 2002
    E39M5, E500 4WD
    I'm not going to argue with you Ross. It really pains me that you've said this, on this forum. I'm leaving it at that, because I like you.
    The cylinder head of an M54 can't be machined 15 thousandths of an inch. It's garbage. and the block is probably garbage too. And that's why you just don't mess with it, you buy a damned used replacement engine for five hundred bucks.
    2002 BMW 325i Sedan (E46)
    L6-2.5L (M54)
    Milling Tolerance
    Cylinder Head Height Standard
    Cylinder Head Height Standard mm 140.0
    Machining limit
    mm 139.7
    Max. warpage allowed 0.05mm
    Chris Powell
    BMWCCA 274412
    Northern VA
    97 M3/4/5; 04 M3 6M
    I think you know all you need to about your "reputable" machinist who shaved 0.015 from a BMW head without asking you first. On the other hand, and I'm not casting aspersions (I've made some colossal mistakes with my DIYs, well chronicled here ), but your description makes it sound like an installation error or defective head. If it isn't something like you dropped it on that corner when reinstalling or transporting it, it could be the prep work you did (as already mentioned). Maybe you'll find the gasket is screwed up.
    In any case, it does sound like you should at least take the head off and investigate before going all-in on a replacement engine...you think a head gasket job is a pain...! And, afterall, you haven't noticed any die leaking from the block, right? Chris would know way better than most whether there is risk from the now super-high compression and low clearance, which, by the way, can be fixed with a thicker gasket with the blessings of BMW (they list using a thicker gasket in the TIS).
    Also, leaking overboard from the corner...OMG does that bring back some bad times. Sorry to hear it. Best of luck. Keep us posted, if you would.
    Northern VA
    97 M3/4/5; 04 M3 6M
    I just noticed that you applied the "reputable" adjective to the gasket. My sentiment is unchanged...stay away from that shop except to try to get some money back.
    Mar 2018
    Ohio
    Well I did use the oversized Victor reinz head gasket to compensate for the material being taken off the head. I tried to find low cost engines, but the cheapest thing I can find is $900. I'm in Ohio.
    NW suburban Chicago
    hiss by my window
    @Chris,
    I knew you would cringe.
    The alternatives are all expensive, especially if considered as a proportion of that car's value.
    Do you think it's worth trying to snug up the head bolts?
    Mar 2018
    Ohio
    When I did this job, I time serted all of the head bolt holes... When tightening the first time, a couple of the time serts stripped out of the block also. So I used big serts on those and tried again with yet another set of head bolts since I had already stretched a few of them before the rest stripped. During the final install, I followed proper torque procedure. During the second round of 90 degree turns, I felt 2 of them start to become weak. They did not strip, but I knew they were close. I already stretched all the bolts and didn't have another set to use, so I just left it as it was and hoped it would hold. Obviously they did not.
    Today I removed the valve cover and saw that the ones that were becoming weak had actually become completely free and were finger loose.
    I had a total of 3 holes needing repair, and luckily I had 3 more big serts left. And I have another gasket waiting as well.
    Soo.... Yeah I realize that even though they were already beginning to strip when I first reinstalled everything, they probably pulled because the head warped more. However, I assume I can't have any more surface taken off the deck. So I'm not sure what I can do besides to bolt the darn thing back on and hope for the best.
    I know a replacement engine is the best way to go. I fully understand that, however, location is a huge issue for an engine swap, not to mention that I can't find one for a decent price. Found 2 around $900 with 150k miles...
    Planning to put it all back together in the next day or 2 and see how it goes. If this fails, then hopefully I will at least be able to drive it far enough to get to a location where I could actually do the engine swap
    NW suburban Chicago
    hiss by my window
    The writing was on the wall the whole time, why didn't you mention this before?
    "So I'm not sure what I can do besides to bolt the darn thing back on and hope for the best." Might as well, you'll know if it's gonna' work or not once you run the bolts down.
    Good luck
    Mar 2018
    Ohio
    Well I've had several posts with this issue. Didn't realize this coolant leak was related to the same issue until I found out it was leaking from the head, and took it apart. I'll update you guys once it's back together. Thanks for all the advice
    Jun 2002
    E39M5, E500 4WD
    I'm sorry that it's ended this way for you. I hope you'll see that this engine is DONE, and not waste any more time and money on it. Nine hundred bucks would be significantly cheaper than what you'll have spent on this trashed motor, before it fails you AGAIN. That said, if you go to Car-Part.com, you can STILL find an M54 for 5 or 600 bucks in or near Ohio. (Ask for a warranty....three months is common.)
    By the way, Time Serting this block needs to be done with a fixture, or the holes are rarely dead straight, or dead center, so they strip out again when you tighten the bolts.
    And, since you have a fluid leak from the block/head....are you absolutely sure that the head bolt holes in the block didn't have ANY coolant or oil in them, before you torqued them, especially since you redid it more than once? (Just a few drops of coolant in a head bolt hole will cause the block to crack when you torque the head)
    Chris Powell
    BMWCCA 274412
    Mar 2018
    Ohio
    Yes I'm sure there was zero fluid of any kind in the holes when I torqued them. After time serting them I cleaned them out with rags and wd-40 then let them sit for a day or 2... I'm curious as to why this would cause it to crack though? Is it just because there isn't room for the bolt AND the coolant together in the hole? Not doubting you just curious as to why that would happen.
    And thank you for the website. As I mentioned on previous threads, I am usually not too keen on using different websites online, but I trust the stuff you guys recommend on here. I'll check it out.
    All in all it's not a huge loss if this engine doesn't work out. Most of the money spent was on parts for the cooling system and a couple other things that should have been replaced even with a new engine. In total, IV spend maybe $300-400 on the actual engine. And most of that is for tools like the time serting kits and the vanos timing tools. If nothing else I gained some tools and a good deal of knowledge thanks to you guys. Overall it's been a positive experience even if it ends poorly
    Jun 2002
    E39M5, E500 4WD
    Liquid doesn't compress.
    To clean out bolt holes, you need to use brake clean and compressed air, not rags and WD 40.
    That website has listings from hundreds, even thousands of salvage yards. I'm not vouching for any of them, just giving you a resource.
    Chris Powell
    BMWCCA 274412
    Joppa, Md
    99 M Coupe,04 K1200rs
    $900 is about 100 times more than Bar's leak, I've seen it work maybe 30% of the time, so easy, its funny.
    NW suburban Chicago
    hiss by my window
    Are you going to try to re-do the Time-serts? Those bolts were talking to you, you know.
    You have a great attitude so I'm sure you'll get this done one way or another.
    FWIW, if you replace this engine you've a fair amount of bits from the old one that ought to sell quickly and recoup some of your investment
  1. Using UV dye to find coolant leaks?
    By ElleShooTiger in forum 1996 - 2003 (E39)
    Last Post: 12-22-2011, 12:17 AM
  2. fixed overheating problem but can find coolant leak
    By mitchelllanier in forum 1991 - 1999 (E36)
    Last Post: 01-26-2010, 07:16 PM
  3. Hard to find coolant leak. Bring on the ideas
    By rotaryboots in forum 1988 - 1996 (E34)
    Last Post: 12-02-2009, 01:46 PM
  4. Cant find coolant leak, but i did find this PLEASE HELP
    By offsetfactor in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-29-2007, 02:49 PM
  5. help find coolant leak on a 540
    By Hypr5 in forum 1996 - 2003 (E39)
    Last Post: 02-21-2007, 09:41 PM
