RM European Auto Parts
Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
Thread: Can't find coolant leak
  1. #26
    Mar 2018
    Ohio
    2001 BMW 325xi, e46, m54
    Quote Originally Posted by 325bob View Post
    $900 is about 100 times more than Bar's leak, I've seen it work maybe 30% of the time, so easy, its funny.
    If it was simply a failure in the gasket it may work, however, I would imagine that if the bolt is tearing out of the block, then the 2 surfaces really aren't even mating anymore. I don't know that stop leak could do anything about that. I could be wrong, just my thought process on it.
  2. #27
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I've seen it work 100% of the time, to clog the radiator, heater core, and ruin all the new cooling system parts. Absolute male bovine excrement! The "funny" part is having to scrape the hardened masses out of the thermostat housing and hoses and other cooling passages when you end up with that new engine, and you've ruined the entire cooling systen.
    Just throw a few tubes of two-part epoxy in there, if you're really determined to kill the car.
    Chris Powell
    BMWCCA 274412
  3. #28
    Dec 2013
    Chicagoland area
    EXOTICS
    Bar's Leak...
  1. Using UV dye to find coolant leaks?
    By ElleShooTiger in forum 1996 - 2003 (E39)
    Last Post: 12-22-2011, 12:17 AM
  2. fixed overheating problem but can find coolant leak
    By mitchelllanier in forum 1991 - 1999 (E36)
    Last Post: 01-26-2010, 07:16 PM
  3. Hard to find coolant leak. Bring on the ideas
    By rotaryboots in forum 1988 - 1996 (E34)
    Last Post: 12-02-2009, 01:46 PM
  4. Cant find coolant leak, but i did find this PLEASE HELP
    By offsetfactor in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-29-2007, 02:49 PM
  5. help find coolant leak on a 540
    By Hypr5 in forum 1996 - 2003 (E39)
    Last Post: 02-21-2007, 09:41 PM
