Results 1 to 6 of 6
Thread: WTB: LSD for 91 535i 5spd. Can i use a 3.15 diff? Will it = better mpg?
    Feb 2013
    san antonio, tx
    91 535i 00 740i sport 98
    Prod Date: 10/91. I only ask because my 535i is going to become my long distance commuter. Was thinking a 3.15 LSD might give me better mpg. Isnt it a 3.46 stock diff?
    Nov 2017
    Grand Haven, MI
    1990 535i 428k miles
    Idk about city mpgs, but you should probably get a better highways. I think when i went from 3.91 to 3.43 i went up 1 or 2 mpgs.
    Moderator and Owner of the Subreddit r/E34
    Feb 2013
    san antonio, tx
    I will be driving 300mi round trip every weekend so thats what im thinking.
    NW suburban Chicago
    hiss by my window
    Your cruising revs will be ~10% less so 2700 @ 80mph instead of 3k. Yeah, I think it should improve highway MPG. You'll probably notice a bit less passing power too.
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    Depends on your cruising speed. If at 60mph may be no difference or even worse as the engine rpm is too low putting u in a less efficient rpm range.
    Maybe change the exhaust narrowband sensors to get more mpg, and clean your maf with the maf cleaner spray.
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Assuming you mean a large-case diff from a 750iL, it won't fit the driveshaft. The boltpatterns for the driveshaft CV and the axles are the same, but the input flange sticks further forward. A driveline shop can shorten the shaft for you to the tune of ~$100-150, and then it'll work.
    I switched from a 3.15 to a 2.65 in a 544iT and fuel consumption decreased by ~8%.
  1. 91 535i M30B35 running rough. Help with test 15 OBC codes pls!
    By Ricky318i in forum 1988 - 1996 (E34)
    Last Post: 02-06-2017, 02:54 AM
  2. WTB 89-95 525i 5spd. or 91-93 535i 5spd.
    By harveykrishna in forum 5 series & 6 series
    Last Post: 04-09-2011, 01:10 PM
  3. E34 91 535i 5spd tastefully modified $5500 OBO
    By ChaoticZen in forum 5 series & 6 series
    Last Post: 10-25-2010, 04:25 PM
  4. E34 MO: 91 535i 5spd
    By MadFish in forum E34 Classifieds (closing soon)
    Last Post: 08-23-2010, 12:09 AM
  5. E34 MO: 91 535i 5spd
    By MadFish in forum 5 series & 6 series
    Last Post: 08-13-2010, 05:12 PM
