Results 1 to 5 of 5
Thread: 535i exhaust clamp options
    Anacortes,WA
    E34 535i; E36 325is
    Some total moron prior owner used some non-standard bolts on the exhaust donut flange clamps on my '89 535i, and the bolts are totally fused with the metal of the flange. No amount of cherry-red heating with a torch, or attempts to break the bolts loose with a breaker bar, thermal shocks by cold water after red-hot heating, or penetrating oil helps. The metal shanks of the bolts have fused with the metal of the two flanges, i.e., completely filled and sealed the bolt holes.
    I've cut the bolts between the flanges to separate the fore and aft sections of the exhaust pipe/cat/muffler assembly, but cannot get the bolts out of the flanges. I may have to simply cut off the flanges, then find an aftermarket replacement such as this:
    https://www.amazon.com/Nickson-Indus...n+split+flange
    Will this or otherwise what aftermarket flange clamps will work with our flared exhaust pipes/donut rings? What size fits best?
    NW suburban Chicago
    hiss by my window
    Why not just burn out the old bolts? Seems like you have torches
    Jan 2017
    Carrboro, NC
    '91 525i (5sp)
    Not sure if this might help... Maybe you can drill out the old bolts and then restore the thread with a tap? It happened to me with an oxygen sensor (had to get an "oxygen sensor thread restorer" -basically a huge tap, but same idea).
    Reinholds, PA
    85 344i, 89 535i
    I used 2 of these for my 89 535i when I had to cut the down pipes. These things are absolute beast clamps, it's the same design idea as a generic band clamp but they are significantly stronger - they will support the weight of the exhaust system, where a band clamp typically will not. They also seal very well.
    https://www.fcpeuro.com/products/aud...amp-191253141f
    They are OEM clamps for various manufactures/models, and come in various sizes. You have to do a bit of digging to find the size you need, and the prices are all over the place. The one I linked to above fits the down pipes, but I am not sure if that measurement is the same for the rest of the system.
    85 325e m60b44 6 speed / 89 535i/5
    e30 restoration and V8 swap
    The finished product!
    Anacortes,WA
    E34 535i; E36 325is
    To answer my own question about Nickson aftermarket exhaust clamps, yes they do fit in 1.75" to 2.0" size, about $5 each at Autozone. The factory clamps are made of some seriously hard steel, but can be cut off with a Dremel reinforced ceramic disk, or a cutoff saw.
  1. E60 535i exhaust options
    By munge63 in forum 2004-2010 (E60,E61)
    Last Post: 06-14-2016, 08:51 AM
  2. E34 535i Exhaust options
    By Rkdgoham in forum 1988 - 1996 (E34)
    Last Post: 08-20-2015, 06:27 PM
  3. 08 535i exhaust options
    Last Post: 11-22-2011, 04:33 PM
  4. e34 535i exhaust options
    By fuzion008 in forum 1988 - 1996 (E34)
    Last Post: 07-15-2007, 03:44 AM
  5. exhaust clamp & rattling ...
    By ccblanket in forum 1991 - 1999 (E36)
    Last Post: 02-12-2004, 07:24 AM
