Results 1 to 3 of 3
Thread: e30 sedan left rear power window not working but right rear does
    Northridge, CA, USA
    1992 BMW 325i
    please help me figure this out
    all power window switches are lit up around the shifter. both front and rear right window work. the rear driver side window switch doesnt even light up. i thought at first it was the switch, so i swapped the switch from the working rear right window and it still didnt work, no lights either. i dont think its the window breaker switches at the top of the shifter since the rear right still works. i think there is only 1 fuse that controls all windows, so i dont think its a fuse.
    i am assuming there is no power going to that door, but where can i trace it and fix it? is it the window motor? but if this was dead would the switch not light up either?
    please help.
    Regina, Sask, Canada
    82 320i 89 325i
    break in the wiring, bad motor, or bad window regulator assembly.
    pull door apart, remove motor from regulator, do not disconnect from wiring, try with switch. if the motor works then regulator has to be the problem. if not then the motor or wiring is suspect.
    Apr 2015
    Toronto
    e30s
    As mentioned above check for a broken wire. if there is NO power at all going to the switch ( no illumination ) it tells me the switch is not getting power. So there most likely a break in the wiring going into the switch rather then exiting. If the switch is "dead" then power is not entering the switch. I'd remove the center console and start probing there.
    Common problem with sedans; there is an accordian between the b pillar and rear door. with the frequent opening and closing sometimes the wire breaks in that junction.
  1. Rear power window not working.
    By amitsekhon in forum 2004-2010 (E60,E61)
    Last Post: 03-20-2016, 11:54 PM
  2. E30 1989 fuse 17 no power, windows not working
    By billygates in forum 1983 - 1991 (E30)
    Last Post: 06-22-2015, 04:26 AM
  3. power windows not working!
    By bmwdrifter in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-07-2004, 08:00 AM
  4. rear power windows stopped working
    By Nmathews in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-03-2004, 08:28 PM
  5. power windows not working/auto circuit breaker pressed
    By BossBimmer in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-15-2003, 08:58 PM
