Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 82
Thread: HELP!! Aux fan comes on high as soon as car started
  1. #51
    Nov 2012
    Lewes,DE
    1997 540i
    Yes, disconnect the switch you added.....then.....
    If F7 still blows pull out the low speed relay.
    If F7 still blows then the you have a short somewhere between F7 and the relay socket.
    If F7 doesn't blow then you have a short between the relay socket and the resistors mounted on the fan frame.
    Jim, I pulled all of the connections to the IHKA panel and turned the key and Fuse 7 still blows
    Quote Originally Posted by BimmrMeUpSnotty View Post
    LMA OFF!!! Some people should know their limitations and bring the hacked up car to the shop...Poor E39...
    The car runs awesome otherwise A$*hole
    Electric Fan conversion, 840Ci thermostat, Dinan style CAI,de-screened MAF, Dinan transmission chip, 255lph LS1 fuel pump, drilled slotted rotors, 3.15 differential, Bel rx65 radar (hard-wired). Hemi Killer!
  2. #52
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    LMF’ingA OFF!!! You go boi... enjoy how great your car goes, too bad your a$$ is cooking in this here summer heat... What are you at now? Medium rare? Keep rigging that thing up the way you’ve been doing, pretty soon, it’ll catch fire, then your sorry butt’ll be well done... Enjoy!
  3. #53
    Nov 2012
    Lewes,DE
    1997 540i
    The A/c works still and it works great actually, i have a 95c thermo and the coolant temp never goes past 103 with the A/c on and no aux fan. The aux fan would keep it a few degrees cooler only. The only thing i have "rigged" is that one wire as a test, I wouldnt have done so if i had my question answered sooner. I asked for days about doing this and got no responses. I have owned many 540i's throughout the years and know these car VERY well. So, if you are not here to make a positive comment or try to help ,then do us all a favor and do not comment on here. Have a good night.
  4. #54
    Feb 2014
    Alexandria, VA
    You know these cars very well.... You’re a mechanic, as you have claimed on another fiasco of a thread... Whatever... Keep rigging that car, see where it gets you. Have fun...
  5. #55
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Be nice boys.
    Sounds to me like you have a wiring harness short somewhere.
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  6. #56
    Nov 2012
    Lewes,DE
    1997 540i
    You were asked to no longer comment, i will have you banned if you persist. Thank you
  7. #57
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    I'd use an ohm meter to find the shorted wire. If there are more hacks they need to be removed.
  8. #58
    Nov 2012
    Lewes,DE
    1997 540i
    what are "hacks? I have only ran this one wire to a toggle switch for the A/c high speed. The only other thing i have done is my 100 watt 12 ohm resistor for my thermostat heater which i have proven is a great mod to satisfy the DME, I do programming on these cars.
  9. #59
    Feb 2014
    Alexandria, VA
    “What’s a hack... ?”
    Pssst.... 97-1, go back to the beginning of this thread, read all your posts, let us know if you need another feeding...
    No free feedings today.... Go see all your other threads.
  10. #60
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    So you have no high speed resistor, an extra manual toggle switch, and a hacked up fan.
    Put it all back to stock, replace the fuses and relays, and check the wiring harness for shorts before you do that.
    If your car burns to the ground... well, it wasn't BMW's fault.
    Nate J.
  11. #61
    Nov 2012
    Lewes,DE
    1997 540i
    Quote Originally Posted by computiNATEor View Post
    no this is a show car, and the ac has always worked great, was missing the high speed resistor when i bought the car. There was never a hack or a manual switch ,that was a test i was performing. Everything on the car is immaculate and stock. all of the relays are fine and all of the fuses are good. I need help at this point to find the short. I suspect it is between F7 and the low speed relay according to Jim's advice.
    how about stop commenting on my posts unless u are here to help , you have been told this numerous times, thank you
    Last edited by JimLev; 06-26-2018 at 12:53 AM. Reason: Time for both of you to chill out
  12. #62
    Feb 2014
    Alexandria, VA
  13. #63
    Feb 2014
    Alexandria, VA
  14. #64
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Thanks for the cleanup Jim.
  15. #65
    Nov 2012
    Lewes,DE
    1997 540i
    Quote Originally Posted by philly98540 View Post
    Yes thank you Jim, you have been extremely helpful! I will message you back soon!
  16. #66
    Nov 2012
    Lewes,DE
    1997 540i
    Quote Originally Posted by ninetyseven1 View Post
    Jim i tested. Key on posituon 2 and fan un plugged (or else fuse 7 blows) I tested wire in terminal 85(black/red) to chassis ground and got a reading of like 7.68? Set the meter to ohms lowest setting too . Then tested the terminal 87 wire (black/ brown ) and got no reading , then tested the black /brown wire in the unplugged side of the connecter at the aux fan and got no reading . Should I have plugged in fan during this whole thing ? should I have tested the black / blue wire at the high resistor ?
  17. #67
    Dec 2013
    Chicagoland area
    EXOTICS
    The reading of 7.68? I'm confused,
    what specific readings are you seeking?
  18. #68
    Nov 2012
    Lewes,DE
    1997 540i
    Ohms lowest setting on my meter !
  19. #69
    Jul 2011
    hillsborough n j
    2001 540i sport 6spd
  20. #70
    Feb 2014
    Alexandria, VA
    CHILL OUT, or its vacation time.
  21. #71
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    LOL. ThatsSnot how banning works, Ol'97.
    You get banned for being a nasty wanker and breaking rules. There's a distinct LACK of a "thread posters have the power to say who posts and who don't post in their threads" rule.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  22. #72
    Nov 2012
    Lewes,DE
    1997 540i
    I will say whatever i feel necessary. Some one needs to address this POS Bimmermeupsnotty POS. He's not helping and I have already to talked to the admins about him, he WILL be banned if he persists
  23. #73
    JimLev's Avatar
    Sundance Mesa, NM
    I will say whatever i feel necessary. Some one needs to address this. He's not helping and I have already to talked to the admins about him, he WILL be banned if he persists
    Dont forget this works both ways. At the moment your on very thin ice.
  24. #74
    Nov 2012
    Lewes,DE
    1997 540i
    Let just keep working together via private message then , there are too many distractions due to members like Bimmermeupsnotty. Thank you for setting him straight Jim!
  25. #75
    Dec 2013
    Chicagoland area
    EXOTICS
    The reason I ask is; how can you be attempting resistance readings,
    while powering up the electrical system on position 2?
  1. Help: Aux Fan on high when lights are on
    By Jdotsturn in forum 1996 - 2003 (E39)
    Last Post: 08-08-2011, 06:27 AM
  2. HELP! aux fan resistor not found URGENT!!!
    By SleekBMW in forum 1996 - 2003 (E39)
    Last Post: 09-15-2009, 06:59 AM
  3. Help! Aux Fan Switch?
    By goyongj in forum 1991 - 1999 (E36)
    Last Post: 07-02-2006, 08:26 PM
  4. Help! Aux Fan problem; no fuse #40?
    By Nivola in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-26-2005, 05:30 PM
  5. aux fan comes when car is cold
    By westcp in forum 1991 - 1999 (E36)
    Last Post: 11-12-2004, 06:39 PM
