Electric Fan conversion, 840Ci thermostat, Dinan style CAI,de-screened MAF, Dinan transmission chip, 255lph LS1 fuel pump, drilled slotted rotors, 3.15 differential, Bel rx65 radar (hard-wired). Hemi Killer!
LMF’ingA OFF!!! You go boi... enjoy how great your car goes, too bad your a$$ is cooking in this here summer heat... What are you at now? Medium rare? Keep rigging that thing up the way you’ve been doing, pretty soon, it’ll catch fire, then your sorry butt’ll be well done... Enjoy!
The A/c works still and it works great actually, i have a 95c thermo and the coolant temp never goes past 103 with the A/c on and no aux fan. The aux fan would keep it a few degrees cooler only. The only thing i have "rigged" is that one wire as a test, I wouldnt have done so if i had my question answered sooner. I asked for days about doing this and got no responses. I have owned many 540i's throughout the years and know these car VERY well. So, if you are not here to make a positive comment or try to help ,then do us all a favor and do not comment on here. Have a good night.
You know these cars very well.... You’re a mechanic, as you have claimed on another fiasco of a thread... Whatever... Keep rigging that car, see where it gets you. Have fun...
Be nice boys.
Sounds to me like you have a wiring harness short somewhere.
Nate J.
(oOO\ (|||)º(|||) /OOo)
(eŌō\ (||||)º(||||) / ōŌe)
I'd use an ohm meter to find the shorted wire. If there are more hacks they need to be removed.
“What’s a hack... ?”
Pssst.... 97-1, go back to the beginning of this thread, read all your posts, let us know if you need another feeding...
No free feedings today.... Go see all your other threads.
So you have no high speed resistor, an extra manual toggle switch, and a hacked up fan.
Put it all back to stock, replace the fuses and relays, and check the wiring harness for shorts before you do that.
If your car burns to the ground... well, it wasn't BMW's fault.
Nate J.
no this is a show car, and the ac has always worked great, was missing the high speed resistor when i bought the car. There was never a hack or a manual switch ,that was a test i was performing. Everything on the car is immaculate and stock. all of the relays are fine and all of the fuses are good. I need help at this point to find the short. I suspect it is between F7 and the low speed relay according to Jim's advice.
how about stop commenting on my posts unless u are here to help , you have been told this numerous times, thank you
Last edited by JimLev; 06-26-2018 at 12:53 AM. Reason: Time for both of you to chill out
Thanks for the cleanup Jim.
Jim i tested. Key on posituon 2 and fan un plugged (or else fuse 7 blows) I tested wire in terminal 85(black/red) to chassis ground and got a reading of like 7.68? Set the meter to ohms lowest setting too . Then tested the terminal 87 wire (black/ brown ) and got no reading , then tested the black /brown wire in the unplugged side of the connecter at the aux fan and got no reading . Should I have plugged in fan during this whole thing ? should I have tested the black / blue wire at the high resistor ?
The reading of 7.68? I'm confused,
what specific readings are you seeking?
CHILL OUT, or its vacation time.
2003 M3CicM6 TiAg
Former:
1985 MB Euro graymarket 300SL
I will say whatever i feel necessary. Some one needs to address this POS Bimmermeupsnotty POS. He's not helping and I have already to talked to the admins about him, he WILL be banned if he persists
The reason I ask is; how can you be attempting resistance readings,Jim i tested. Key on posituon 2 and fan un plugged (or else fuse 7 blows) I tested wire in terminal 85(black/red) to chassis ground and got a reading of like 7.68? Set the meter to ohms lowest setting too .
while powering up the electrical system on position 2?
