Results 1 to 10 of 10
Thread: Chirping Sound while turning steering wheel at idle.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    Hi all... 1995 525i 5SPD 278k
    For some reason while the car is on and at a stand still, as I turn the wheel there's a loud chirping continuous sound until I drive. It doesn't occur while I'm driving. Only when I'm at a stand still the chirp occurs. It's been happening for quite some time. I removed the belt a while back and put it back on (the same belt) and the chirp stopped. Gradually the chirping cam e back. It is very annoying and embarrassing. I have to drive as I turn to avoid the continuous chirp sound. Any idea what it could be? Belt looks good. Pulley look good. It only occurs when the car is on and not moving.
    Thanks in advance.
    Nov 2017
    Grand Haven, MI
    1990 535i 428k miles
    Same thing occurred to me. You need a new belt. Even though it’s tensioned properly, they wear out on the edges and don’t fit into the V on the pulley. It only occurs while not moving because it’s less work for the steering pump to move the wheels while the car is moving. Hope this helps!
    Moderator and Owner of the Subreddit r/E34
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by moroza View Post
    Is it tensioned correctly? PS fluid ok?
    Most likely a belt issue as indicated, however the power steering reservoir contains a non serviceable filter. How old is your fluid? Replace the reservoir and fluid.
    Nov 2017
    Grand Haven, MI
    Quote Originally Posted by bluptgm3 View Post
    To add onto this, when you take off the belt. Make sure you can spin the pump freely with your hand.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    I'm going to assume it's tensioned correctly. Fluid is at level but, I haven't changed it since I had the car (two years). I'll buy a new belt and do a flush.
    moroza's Avatar
    BFE
    E34T
    Checking and readjusting the tensioner is free...
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    agreed.... Isn't the belt tensioner self adjusting?
    moroza's Avatar
    BFE
    E34T
    No. It's spring-loaded but you still have to set it to the correct position. Also, the spring can wear out. If the tensioner is already at the tightest position, and the PS pump turns by hand, the last thing I'd try before a new belt (cheaper than a new tensioner) is swapping the main belt and AC belt tensioners (same part, easy swap), and see if that helps. Of course they could both be bad, but that's less likely. The tensioners are common to lots of 90's BMW's, easy to find used.
    Mar 2014
    Rotterdam, NY
    2011 BMW 328xi Auto
    I removed the AC belt a while back, since the AC unit wasn't blowing cold air. I will definitely check the tensioner and I ordered a new belt. Thanks for the info!
  1. Scratching sound when turning steering wheel
    By Donlundm3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-21-2016, 09:46 AM
  2. Clunking sound when turning steering wheel
    By vtince in forum 1976 - 1989 (E24)
    Last Post: 06-24-2016, 11:35 PM
  3. screeching sound when turning steering wheel to the end
    By X1mne in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-04-2013, 09:54 AM
  4. Strange sound when turning steering wheel
    By art818 in forum 2002 - 2008 (E65, E66)
    Last Post: 02-07-2012, 01:08 PM
  5. Weird sound while turning the wheel....
    By beemderv in forum 1995 - 2001 (E38)
    Last Post: 08-18-2010, 06:40 PM
