Results 1 to 8 of 8
Thread: What sensor is this & Why is it leaking oil? ['03 525i Sport]
    Jun 2017
    Chicago
    2003 BMW 530i M Sport
    Photos: https://imgur.com/a/iHudqRr
    It looks to be the sensor just above a large coolant hose at the front of the car, passenger side below the valve cover gasket. I just replaced the valve cover gasket like less than 10k miles ago, so I don't think that's it? However it appears to be leaking from the black sensor that sticks out. What is it and how do I replace it / how much does it cost?
    Mar 2017
    Adelanto California
    2000 BMW 528i
    Looks like your variable timing solenoid. Either it has gone to crap (broke), the O-ring is long gone, or it wasn't screwed back in properly (either loose or wasn't threaded in properly causeing morphed threads which is really bad. Hopefully the threads aren't the case)
    Sent from my SM-G955U using Tapatalk
    Sonoma Whine Country
    E12, E12, E36, E39
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
    Jun 2017
    Chicago
    Quote Originally Posted by PostChris909 View Post
    Okay, can you link me the part # please?
    Quote Originally Posted by Mike WW View Post
    Uhh, your post is blank?
    Mar 2017
    Adelanto California
    2000 BMW 528i
    I believe the cross reference number is 11367524489. I'm not exactly sure but nonetheless, always go oem for any kind of sensors for BMW's. These cars are very particular of their organs and blood type, just do your research and pay the price, or you'll Really be paying the price if you buy a cheapo offbrand
    Mar 2017
    Adelanto California
    2000 BMW 528i
    Double check the part before you buy. Look up a procedure on how to remove it safely, then report back with the part so any of us can Id this part for sure
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    PostChris, your number is for the V8, not for his 530.
    Number 2 should be it. Not sure why they only show the intake solenoid and not where the exhaust solenoid goes.
    http://www.realoem.com/bmw/enUS/showparts?id=DT63-USA-04_2000_E39_BMW_530i&diagId=11_7521#11361432532
    Los Gatos CA
    1987 325is, e34, Z3, e39
    That's a fair amount of oil on the connector for the VANOS solenoid. While it might be the solenoid o-ring, it seems more likely that it's from the exhaust cam position sensor. That also has an o-ring. The original o-ring was a high quality green HNBR o-ring which rarely goes bad, but if someone replaced the sensor (which are known to fail) they may have also replaced the o-ring with one that degrades more quickly.
  1. What is this part (m42 head) and why is it leaking oil ??
    By Danny318 in forum 1991 - 1999 (E36)
    Last Post: 11-01-2006, 08:44 PM
  2. oh my god, why must it leak oil, why??????
    By jrward in forum 1991 - 1999 (E36)
    Last Post: 03-21-2006, 10:39 AM
  3. Why am I leaking?
    By AndyZ3 in forum 1991 - 1999 (E36)
    Last Post: 03-31-2004, 06:25 PM
  4. Politely ask: Why do people put Video in their sports cars
    By archyx in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-09-2003, 08:27 PM
  5. Why does every M3 with H&R sports look lower than mine?
    By Drifto in forum 1992 - 1999 M3 (E36)
    Last Post: 01-24-2003, 04:46 PM
