It goes on top of the spare tire under the carpet, you may have noticed it’s got some threads on the top, it just screws on to the long thread that the tire sits in I believe.
That's the wrench to remove the center cap on your wheels.
http://www.realoem.com/bmw/enUS/show...86#36131181948
Sent from my SM-T817V using Tapatalk
00 740iS
84 635 (euro)
88 M6
84 745i
88 325iX
92 850i (6 spd)
Both right - it does both jobs!
My BMW Repair YouTube Channel
Ditto...that is the hub cap wrench for BMW wheel styles that have a specific type of hub cap (like the 16" Style 5 Cross spokes that has slots that accepts the "fingers" of the hub cap wrench). When in use...you insert the fingers of the tool into the slots in the wheel's hubcap...then you take the lug wrench to twist the hub cap off. When not in use...it sits atop the threaded bolt that secures the spare in the trunk.
BTW, the BMW part number is molded into the wrench's design, for items like this...you can just go to one of the online part databases and enter the full 11 digit part number (or the last 7 digits of the part number if you don't have all 11)...and this can reveal where and what an unknown item is.
{here's two hub cap types that use the hub cap wrench you pictured}
Great, thanks all (also for the suggestion of using an online database). regards, Sopado
I just use a screwdriver to get my center caps off.... there's a tool???? LOL Am I NOT supposed to use a screwdriver?
How the heck does the tool work??
2001 740iL "Silver Beauty"
1986 Porsche 951 "Silver Bullet"
1987 Porsche 944 NA Auto (rebuilding for my son's first car)
https://home.doonze.net/filepage.php <- BMW/Porsche doc's and files, work in progress
Along with the pics above that shows two of the few types of hub caps that use the hubcap tool...you can see the owners manual instructions (below) how the lug wrench is used to torque the hubcap away from the wheel.
Many users have difficulty using the tool because they press inward while twisting the hub cap off. Since the hub cap is held on with compression instead of being threaded...if you press inward while twisting the hub cap off...it just spins and doesn't come off. On occasion I've had to take the tool from wheel jockeys after telling them not to press inward while twisting the hubcap off...then in less than 3 seconds...turn the hub cap wrench approx 1/4 turn...and the hub cap pops right off. Again, it is NOT threaded so DO NOT push inward or put pressure on it as if you're UNSCREWING the hub cap...you are not. The hub cap releases itself when you turn the tool about a quarter turn in the direction indicated to release it. The tool is NOT needed to reinsert the hubcap...to do that you just light up the little arrow on the hubcap with the corresponding arrow on the wheel and push it inward until it snaps into place:
Well dayum! learn something new every time I log on here! Thanks Timm & Q! These guys ALWAYS know what's up
"A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible. There are no prima donnas in engineering." - Freeman Dyson
i done mess with the hub cap so many times with the screw driver on my father's 740il.... oh well...
I noticed that the guy that fixed a nail in the tire had taken it out of the trunk but didn't see him actually use it. I'll have to practice. Good tip!
...just remember, if it isn't popping off within a one quarter turn of the lug wrench...its probably because too much inward pressure (toward the wheel) is being applied and not allowing the hubcap to pop off...
