Results 1 to 7 of 7
Thread: Steering Wheel Removal (non-airbag)??
    Jul 2006
    Southern California
    1989 325i Conv.
    Can anyone post links to good descriptions or videos of how to remove the steering wheel on an non-airbag e30. I need to remove by instrument cluster.
    Also, how hard a job is this from a DIY perspective?
    Thanks in advance.
    Nov 2012
    West Point, Virginia
    2002, 320is, 328is, M3
    Youtube has a bunch. Pretty easy.
    https://www.youtube.com/watch?v=vLWckwNDGSw
    ME:"I want to make my car faster and lighter"
    THEM:" Get out and let someone else drive"
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    You don't need to remove the steering wheel to pull the cluster. It's easy to remove the cluster with the steering wheel in place, just a couple wigs and wags and it clears the wheel.
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    For the first time I'd remove the wheel. It takes all of a minute with a 22mm socket
    Mar 2002
    El Segundo, Southern Cali
    03 530i, 96 328is, E30
    And here's a little tip - the steering wheel will be very tight on the splined shaft and can take a lot of force to yank it loose.
    DO NOT fully remove the big nut from the shaft. Loosen it till it's flush with the end of the shaft so all the threads are still engaged.
    Then pull the wheel hard and rock it back and forth a bit and it should suddenly break free and slam against that backside of the big nut.
    That nut will keep the steering wheel from smashing you in the face when it breaks loose.
    Randy Walters
    '89 325is (Competition car, now sold)
    '96 328is (Weekend Fun car w/M3 suspension, just sold)
    '03 530i Sport (Spare car)
    '05 X3 3.0 (Little Woman's DD)
    '21 Mazda 3 Premium Sedan AWD (Daily Driver)
    BMW CCA & SCCA Driving Instructor
    BMW CCA L.A. & S.D. Chapters
    Multiple SCCA Regional Championships
    CANTON, OHIO
    TRIUMPH tr250,tr6, bmw 325i
    And put your key in the ignition and unlock the steering column before trying to pull your steering wheel.
    Jul 2006
    Southern California
    1989 325i Conv.
    Thank you for all the help--I feel better prepared for my project!! I have a couple of more questions
    First, I have the three spoke steering wheel with the horn button in the center. I didn't see a video to remove this type of wheel. How do I remove the center/horn button? Do I have to unplug any wires or can I just move the horn assembly out of the way.
    Also, do I need to use a torque wrench when I'm putting the wheel back on? I'm happy to buy one if necessary. Any tips for reasonably priced ones?
    Thanks again!!
  1. E36 Re-Wrapped M-Tech II steering wheel (factory non airbag)
    By JacketedLobster in forum Interior Lighting & Body Parts
    Last Post: 11-08-2012, 11:30 PM
  2. Steering Wheel Swap (non-airbag)
    By quattroboy in forum 1988 - 1996 (E34)
    Last Post: 05-22-2009, 02:51 PM
  3. Advice on changing steering wheel (m3 non airbag wheel)
    By curdy123 in forum 1991 - 1999 (E36)
    Last Post: 04-24-2008, 04:22 PM
  4. airbag steering wheel for non question..
    By killa325i in forum 1983 - 1991 (E30)
    Last Post: 09-25-2005, 09:48 PM
  5. 4-spoke m3 steering wheel on non-m Airbag
    By e36Silvr328i in forum 1991 - 1999 (E36)
    Last Post: 04-19-2005, 03:59 PM
