Results 1 to 15 of 15
Thread: Speaker upgrade question
    May 2018
    Philadelphia
    1994 325i
    I have a 1994 325i and probably much like most, my rear deck speakers are shot. I’ve thought about different ways to go about upgrading them. But for now I think I might just go with the newer E36 OEM 6X9 setup. With that being said, I was wondering in anyone has done this and if so, what are your thoughts? Also, I was told that if I decide to go this route, try to get a set out of a 3 Series from 2011 and up because those speakers are better quality.
    Jan 2018
    Earth
    Quote Originally Posted by JasonMHorn View Post
    ...try to get a set out of a E36 from 2011 and up...
    2011 and up?
    Oct 2003
    Seattle
    99 M3
    Production of US bound E36 ended in 1999, AFAIK.
    Euro production ceased in ~2000.
    May 2018
    Philadelphia
    1994 325i
    Quote Originally Posted by bluptgm3 View Post
    Sorry, I meant from a 3 Series not E36. I edited the OP.
    Quote Originally Posted by Bostongruen View Post
    2011 and up?
    Aug 2009
    sunnyvale CA
    325is
    The speaker mounts changed on a std E36 to a E46.
    The 4x6 adapter was invented for more bass but the 328 have a new box for a larger speaker too
    E36 HK system had 4x6
    Note the use of a 3 tab speaker mount on the E46 6.25 inch
    Stock 325
    328
    HK upgrade
    E46
    Oct 2003
    Seattle
    99 M3
    Bavarian Sound Works offer an E36 HK and non-HK kit.
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    ALL E36 stock speakers are shot at this point.
    I put kicker 6x9 components in my deck about 2 years ago and IMO they are an adequate improvement in base. Good compromise between a base box and not ruining your trunk. I'd probably just go the easier route and put coax in though if I had to do it again. Mine are amped with 100w RMS too so they can move. The rear deck grills are a PITA with the speaker foam backed grills. I just removed my foam because it was completely shot. I'd also redo your purple (assuming black interior) rear deck fabric with headliner material while you're at it.
    This is what I used:
    https://www.amazon.com/Kicker-43CSS6...kers+component
    May 2018
    Philadelphia
    1994 325i
    Quote Originally Posted by wgknestrick View Post
    I appreciate the advice. My interior is grey. I was thinking about going with 6X9 so I started looking into them. I saw that some people recommend the brackets from Amazon that allow the speakers to go into the stock area. I like that idea but I don’t like how the speaker is partially block. But I guess that’s the best option for keeping things looking stock as possible. So with my mind made up in going that direction and looking a little more into it I thought about going with a used set of OEMs from a parts car. I figure this way I get the bracket and a pair of HK for a cheap enough price. It’ll work for now and eventually I can just upgrade the speakers and use the bracket.
    Yes I saw that. I would really love to replace all of my speakers with the Bavsound Kit but unfortunately at this time, I really don’t have the money. That’s another reason why I decided to look for an OEM pair from a parts car.
    Oct 2003
    Seattle
    99 M3
    HK system has to be retrofit in complete form, no partial retrofit.
    Amp and wiring included.
    Aug 2011
    Vancouver, BC, Canada
    99 M3 Vert
    Aftermarket speakers are going to be cheaper and aren't that hard to install. If you buy them from Crutchfield, they even include free instructions and all the bits and bobs you'd need to do it.
    Jan 2018
    Earth
    Not mine.
    Oct 2003
    Seattle
    99 M3
    My HK Sound is just fine. Original owner 1999 M3, my wife’s third owner 1998 Sedan M3 has a blown tweeter.
    My sons 328 HK Sound is just fine…
    May 2018
    Philadelphia
    1994 325i
    That’s not true. I had a pair (just like the ones above) in my hand the other day and my plug plugged directly into it. I didn’t buy them because the guy was asking to much for them IMO.
    Aug 2009
    sunnyvale CA
    325is
    You can swap parts but they were not designed for the same system.
    Normal cars have a 4 ohm rear speaker
    HK rear speakers are marked 2 Ohms and 3 Ohms
    You will thus alter the sound balance of the car sound system. More important will the amp be damaged?
    Jun 2015
    Ontario, Canada
    1998 M3 5-Spd Coupe
    Has anyone installed the Bav Sound HK Kit in their car? How do you like it so far?
  1. 525it speaker upgrade question
    By milenium99 in forum 1988 - 1996 (E34)
    Last Post: 06-09-2009, 07:54 PM
  2. Speaker upgrade question
    By dje34M5 in forum 1996 - 2003 (E39)
    Last Post: 07-18-2007, 09:51 PM
  3. DLS/ Polk Audio speaker upgrade question
    By Beermaker in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 02-11-2007, 04:13 AM
  4. Another Stereo/ speaker upgrade question
    By porscheguy in forum 1991 - 1999 (E36)
    Last Post: 07-30-2005, 08:33 PM
  5. Speaker upgrade question?
    By kadaf in forum 1995 - 2001 (E38)
    Last Post: 02-12-2005, 12:54 AM
