Results 1 to 9 of 9
Thread: trunk fluid
    Mar 2016
    portugal
    BMW E65 730D 02
    trunk fluid
    Does anyone know what kind of oil goes in the reservoir for the lifting and closing of the trunk?
    some say ATF is good, others say it ruins the entire system, others say AeroShell Fluid 41 or Pentosin, also that any CHF is good, like motul multi HF.
    I need help, because after reading so much I don't know what to buy.
    or better go to a bmw dealer and by one bottle?
    I donīt want to mess up the entire system, but if I could buy cheap from another place I will, instead buying a small bottle and pay like liquid gold from the dealer.
    thanks guys
    Oulu, Finland
    See my sig
    Aeroshell 41 is original oil. Don't put any other oil in it.
    And if you are low on fluid, usually the cylinder leaks and needs to be replaced.
    Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
    Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
    Mar 2016
    portugal
    BMW E65 730D 02
    thanks,
    no other alternatives to aeroshell?
    itīs hard to find in my country.
    Oulu, Finland
    See my sig
    You can find it on ebay for sure.
    Mar 2016
    portugal
    BMW E65 730D 02
    I will search for it.
    the symptoms are; pressing the tailgate switch or the switch inside the car the tailgate unlocks, I can hear the pump working but I need to help with my hand the tailgate to rise, or else it rises very slow.
    with the tailgate full open I need to hold it or drops right over my head.
    when closing and pressing the closing switch all normal, closes softly and gently.
    Oulu, Finland
    See my sig
    Have you checked your oil level? Another one is that your trunk gas springs are most likely gone. Part 23 and 24 (for automatic trunk lid): https://www.etkbmw.com/bmw/EN/search...7N/ECE/41_1465
    Mar 2016
    portugal
    BMW E65 730D 02
    I didn't, my hint is low oil level, but after what you said I will check the level first then the springs, after that see if I need to refill or not.
    Iīm not sure if gas springs failure are common in this model, at least in the E39 was a common problem but I will check it out before buying the pump oil.
    current rides: bmw E65 730d 02, bmw E39 530d touring 01
    Oulu, Finland
    See my sig
    They go bad on these what I have read. The design on the gas spring has been udpated. I'm having a issue that the trunk works fine, but if the car is at slight angle trunk will slowly close by itself. And also the cylinder leaks tiny bit.
    So I gotta replace the gas springs and cylinder in close future. Nice 330€.
    Mar 2016
    portugal
    BMW E65 730D 02
    I see this is a common issue unfortunately.
    By the way, I saw the aeroshell is mineral, not synthetic.
    I’m a little bit surprised this pumps runs with mineral oil instead of synthetic.
  1. Trunk Mounted Washer Fluid Reservoir Pic Request
    By 93FIM5 in forum 8 Series (E31)
    Last Post: 07-28-2017, 02:33 PM
  2. Trunk washer fluid reservoir pics needed
    By Omega man 1969 in forum 8 Series (E31)
    Last Post: 10-08-2012, 03:14 AM
  3. Best Hydraulic Fluid for trunk?
    By 745Ryder in forum 2002 - 2008 (E65, E66)
    Last Post: 05-21-2012, 05:22 PM
  4. Trunk washer fluid container / pump?
    By moutine in forum 8 Series (E31)
    Last Post: 03-26-2012, 12:14 AM
  5. Mobil 1 ATF Fluid good for my transmission?
    By GreenGiant in forum 1991 - 1999 (E36)
    Last Post: 03-03-2001, 07:11 PM
