Results 1 to 3 of 3
Thread: Bnw e46 oil leak
    May 2018
    Lithuania
    2002 BMW e46 Touring
    Bmw e46 oil leak
    Hello, so I've got a problem as described for my bmw e46 2002 2.0d 110kw. Situation: Was going after work to home, then like after 10 mins were driving to shop, when came back noticed oil on the ground, checked under my car oil was leaking, all oil gone in few hours. Took out collector, there is oil everywhere inside, not sure yet if it should be there or not. By the way when was driving home everything seemed normal, no weird sounds or anything like that. Maybe you folks have any idea where should I check for a problem or it's not worth of trying? Thanks in advice.
    Oct 2005
    San Francisco, CA, USA
    '94 318ic, '00 323it
    There are only a few places it can be.
    Check oil pan , timing chain cover, oil filter housing, valve cover seals and shaft seals.
    Alpine 318ic FTMFW!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    If all of the oil leaked out in a few hours there has to be a major leak. Im betting the oil pan is the culprit.
  1. 02 e46 oil leak got bigger
    By MROD1989 in forum 1999 - 2006 (E46)
    Last Post: 07-12-2012, 12:26 PM
  2. 2003 318i e46 oil leaking from filler cap
    By davyab in forum 1999 - 2006 (E46)
    Last Post: 04-03-2012, 08:44 PM
  3. 2001 325i E46 Oil Leak
    By risaac325 in forum 1999 - 2006 (E46)
    Last Post: 03-17-2011, 11:32 PM
  4. E46 Oil Leak around Oil Filler Cap... ARGH!!!
    By Krueger81 in forum 1999 - 2006 (E46)
    Last Post: 12-28-2010, 10:48 AM
  5. e46 oil leaks // repairs on oahu
    By tyler0630 in forum Hawaii & Other Islands
    Last Post: 06-14-2009, 02:41 PM
