Results 1 to 7 of 7
Thread: 88° Thermo on M62TU: What Should KTMP Values Look Like?
    Roswell, GA 30075
    2003 540i Sport - 6 Spd.
    '03 540i. Running the 88° thermo with temp tables remapped by DUDMD to eliminate the P0128 low-coolant-temp error code.
    Question. I'm in Atlanta, and ambient outside temps have been getting into the low 90s. I drive in stop-and-go traffic, running AC. I'm seeing KTMPs anywhere ranging from the mid 90s to up to around 102°. Is that an acceptable range with this thermo?
    (Yes, I've searched this forum to seek this info. No clear answer that I could find out there.)
    Thanks for your help...
    --Peter
    '03 540i-6
    153k mi; bought April ‘07 w/38k mi
    Silv/Blk, CWP, UUC SSK w/DSSR, M5 diff, JBR LW FW, SPEC Stage 2 clutch, Zionsville w/2-stage fan, coolant hoses, M60 intake manifold, motor-out overhaul (powder-coated VCs, TCGs, valley pan, coolant mani, head gaskets, heads refurb, all other gaskets, seals), Beisan vanos, PS pump & hoses, AC comp, fuel pump & filter, washer hoses, 88-degree thermo, DUDMD tune, Vibrant Racing muffler, Zeck CDV, Brembo solid-disc rotors w/ Textron pads & UUC SS brake lines, Dinan springs w/Koni Yellow shocks/struts, M5 front & rear sway bars, H&R 10mm spacers & studs front & rear, Pilot Sport A/S 3s, headlight adj repair, polished headlight lenses, 6k Umnitza Xenon & AE bulbs, new OEM M-Sport bumpers, gauge rings, permanent seat-twist repair to front seats, ZHP shift knob, M5 headliner kit (reinforced A-pillar clips), Schmiedmann pedals, MID & cluster pixel repair, Bavsound Stage 1 speaker upgrade & dedicated amp w/DSP subwoofers, retrofitted cupholder
    Jun 2013
    Arizona
    '02 540i 6MT
    KTMP is 93 pre-summer ambient temps.
    Now that it's 100+, 93-95 is where she normally sits with the AC running. It will get up to 99-100 sitting in traffic/drive-thru. I"ve seen 102 here and there but that's about the time the aux fan goes into takeoff mode.
    Jan 2015
    Tempe, AZ
    1995 525i/5
    That's not bad at all. I was always under the impression that an 88º thermostat is too cool for the M62tu, but if the average temps are still in the 90º+ range then that's still pretty good in terms of efficiency and whatnot.
    1995 525i 5-speed - Thread
    Roswell, GA 30075
    Thanks, guys. Good to know the values I'm seeing are normal...
    --P
    May 2013
    Chicago, Illinois
    2000 BMW 528iA
    I have an 88 degree thermostat in my lowly 528 and the temps average between 87-90 during the cooler months and between 90-93 during summer. So far its never reached 94 to my knowledge.
    Correction: today it was about 97 degrees here and the KTMP got up to 96 for the first time.
    2000 528i sport
    EMP Stewart water pump
    Dice iPod adapter
    Alpine amplifiers
    MB Quart speakers
    MTX BGE12 subwoofer
    AudioControl EQL equalizer
    Sep 2010
    Ooltewah, TN
    2010 BMW M6*2019 X3 M40i
    In my experience (as some of you know I've sold bunch of 88 C thermostats and got feedbacks from customers), it should be running most of the time at 88 C - 94 C. I think you ought to check operation of your OEM electric fan and your Spal electric fan plus make sure your radiator fins are not dirty / bent.
    Roswell, GA 30075
    Okay. Yes, my SPAL fan isn't coming in at its low speed, which is a separate issue. Think I have the fix for that.
    --P
  1. m62tu DIS nominal/actual value
    By luka117 in forum 1995 - 2001 (E38)
    Last Post: 02-21-2017, 10:14 AM
  2. Fast Idle - M62TU - Where should I start looking?
    By polluted in forum 1996 - 2003 (E39)
    Last Post: 02-28-2015, 07:59 PM
  3. 88 325i Convertile w/60,000 miles-value?
    By Cobra Grover in forum 1983 - 1991 (E30)
    Last Post: 11-19-2006, 09:56 PM
  4. Help with value of 88 m3 pls.
    By rwm514 in forum 1987 - 1991 M3 (E30)
    Last Post: 07-14-2005, 11:40 PM
  5. 88 325 is value - help quick, please
    By hotghias in forum 1983 - 1991 (E30)
    Last Post: 02-11-2004, 10:18 AM
