Results 1 to 3 of 3
Thread: INPA doesn't work on 94 235i, but works on 98 Z3M
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    INPA works fine on my 98 Z3M, but on my wife's 94 325i it says: "IFH-0006: COMMAND NOT ACCEPTED. Program will be stopped!" I re-checked env variables, and that COM1 is correct in both places. (For my S52 I chose "M52", which is correct.) For my wife's car I chose "DME 3.31 for M50 2.5 1", which is her engine. The diff seems to be which car it is plugged into. One guess is that the plug is not connecting due to corrosion (I'm using the plug in the engine compartment). Any other ideas? Something simple I'm missing? .... thanks for any responses.
    Jul 2004
    Houston, TX
    36 Cylinders
    Copy / paste
    Pre OBD2 cars are a completely different diag system, which uses mostly the L - line diagnostic protocols. You will not be able to diagnose that car without a true ADS interface on a true serial port.
    I would use the so called "stomp test" to identify codes on that car.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Thanks. I looked it up and will try it...... (10 minutes later) Just read codes : only "1444" came up (no codes), which makes me happy. My wife told me the "Check engine" light had come on, so I am doing this to prepare for emissions test. So I think she was wrong, because the code is stored, until cleared, even if the problem is fixed. again, thanks...
  1. do rieger kits work with 94 325ci?
    By thadman in forum BMW Rides & Events
    Last Post: 08-16-2005, 06:13 PM
  2. What chip works on 94 325i auto
    By Makster in forum 1991 - 1999 (E36)
    Last Post: 05-12-2005, 08:00 PM
  3. will 96'+ stock stereo work with 94' cd changer
    By vyb2 in forum 1991 - 1999 (E36)
    Last Post: 02-08-2004, 07:36 AM
  4. JIM - What 19" Wheel Size works for '94 325IS ?
    By orionvii in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 05-04-2003, 03:33 AM
  5. Will H&R Race for 94-96 M3 work on 97-99 M3?
    By Lee in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-19-2001, 08:00 PM
