Results 1 to 25 of 25
Thread: RIP....LH inner door pull...and my small rant
    Mar 2003
    somers,ny
    235k miles...99 coupe ...and 6 mos ago orig lh inner door pull shoes some movt/damage, but its still secure.
    Go for a state inspec this am to a shop Ive known for yrs.......I tell the shop dont close door from inside w/ door pull handle!..use ventvwindow frame pls.
    thru the yrs Ive watched if any1 was working on my car(which is rare)..but Ive mellowed a bit and realize life is too short. just trust folks more.
    get in car to leave,,,,,,,,,...door pull is blowing in the wind and no longer attchd at upper end to door panel......foooooooooock
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Looks like someone just got a free door panel. You can't let that slide
    Mar 2003
    somers,ny
    Im not sure I agree....but u do make me think
    I know the shop well. The owner always gives me a break on inspections..
    door pull was on its last legs.....but it was attached
    I prolly coulda got a long time myself out of it....and not have it totally break.
    I think Id feel like an arse coming after the shop for this, but I could be wrong.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by jrkoupe View Post
    ... door pull was on its last legs.....but it was attached. I prolly coulda got a long time myself out of it....and not have it totally break...
    The plastic base of the handle broke first, so the handle was no longer attached to the metal door. by a screw. But the handle was still attached to the door card by the handle's plastic post, which is heat-flared out behind the card. Then the shop broke the post.
    http://www.bimmerfest.com/forums/sho...89&postcount=5
    http://forums.bimmerforums.com/forum...5#post27426485
    BMW MOA 696, BMW CCA 1405
    Mar 2003
    somers,ny
    I forgot about the post!
    thnx vintage!
    so a new handle has a new post as well?
    Aug 2012
    Kansas
    Well at least a decent salvage door card or some other consideration seems fair. Especially since you prewarned them. I had door dings fixed on my 1st roadster and the body shop broke the mirror spacer while taking the mirror off. I didn't even have to ask they proactively bought a salvage replacement and repainted it too
    Mar 2003
    somers,ny
    I see your point....but i left....and its been over 3 hrs...............it wont break the bank.......Im good
    Oct 2012
    Louisville, KY
    ... so a new handle has a new post as well?
    Yes.
    https://www.ecstuning.com/b-genuine-...e/51418398735/
    I repaired the broken plastic screw base with JB Weld, which made the handle usable. But I did not use the handle because of the broken post. I suppose I could have run a long sheet metal screw into the hole where the post broke, from the other side of the card with a fender washer. But I bought a new handle.
    The screw in the base of the handle is a structural connection to the sheet metal door. When the handle's plastic screw base breaks, the handle is only connected by its post to the door card. Probably the flexibility of that, the pulling on the weak card, can be felt when closing the door. That is a warning to take the handle and the card off, and replace the handle, before the post breaks and the front end of the handle comes completely loose.
    Mar 2003
    somers,ny
    I knew most of this......but not all.
    I told the shop to not pull......siiiiigh
    Im going to PM you in about 10 mins
    Oct 2012
    Louisville, KY
    Quote Originally Posted by Vintage42 View Post
    ... I repaired the broken plastic screw base with JB Weld...
    And painted it black. A long sheet metal screw with a fender washer could be screwed into the hole where the post broke off.
    Dexter, MI
    BMW M235iR / SpecE30
    I'm looking for one of these handles, if anyone has one! I bought my car with it already broken and gone.
    -Anthony Magagnoli
    #80 BMW M235i Racing - Pirelli World Challenge TC - 2017 Rookie of the Year
    Rooster Hall Racing / FCP Euro
    '87 BMW SpecE30 #007 - 2012 NASA SpecE30 NATIONAL CHAMPION
    '08 BMW "130i" 6MT, '01 Z3 3.0i Coupe 5MT
    '88 Pontiac Fiero GT 5MT (my childhood dream car!)
    Send Your Teens to Street Survival
    Drive Faster Now
    Oct 2012
    Louisville, KY
    Quote Originally Posted by Z3SpdDmn View Post
    If anyone has a handle to sell, the plastic post must be broken, because that's the only way to get the handle off the door card. My old driver handle is for sale for $50, like this except missing plastic post:
    Oct 2012
    Louisville, KY
    If anyone has a handle to sell, the plastic post must be broken, because that's the only way to get the handle off the door card. My old beige driver handle in Post #10 is for sale for $50, like this except missing plastic post:
    I see from your cracked dash post that you need a black handle.
    Apr 2014
    Newport News , Virginia
    1996 Z3 E36(7) M44
    I had to replace mine with a new one some time ago. The place on handle where it screws to the door is the weak point. I epoxed a small washer on the inside where the screw passes through reinforce it.
    Oct 2012
    Louisville, KY
    Quote Originally Posted by Bob M View Post
    I think you posted about the washer a few years ago, and I was going to do it with my new handle. But the washer that fitted flush at the bottom of the hole seemed the same size as the screw head. I was afraid a washer larger than the screw head might spread, stress and break the plastic base when the screw was tightened.
    Dexter, MI
    Yeah, I'm hoping to find one that's been pulled out of a wrecked/scrapped car.
    Yes, black is needed.
    -Anthony Magagnoli
    Drive Faster Now
    Oct 2012
    Louisville, KY
    Yeah, I'm hoping to find one that's been pulled out of a wrecked/scrapped car...
    As you probably know from this thread, you are not likely to find a handle that has been pulled out of a junk car. For that, the salvager has to find a perfect handle, remove the front screw, and break the plastic post to fee the handle from the card.
    I think any usable handle will have to come from an owner whose handle broke loose, and he repaired the base and did not keep the handle. If you find such a handle, you then have to succeed in using a screw to replace the plastic post.
    Mar 2003
    somers,ny
    well said
    I do think most folks think a used handle is fine,...and they are usually not as the post most likely is broken
    Apr 2014
    1996 Z3 E36(7) M44
    As I recall I took the handle to a Lowes or such and found a washer that did the trick.
    It’s not broken since. I’m sure either way is fine.
    Dexter, MI
    Well, you're right in that I'm not finding any. I'd think if a salvager was stripping a car, he'd pull the entire door card, at which time it would be easy to pull a handle. You might be convincing me to spend the insane amount of money on the new one. The previous owner of the car said he "had one on order from the dealership", but it was BS, as I fully expected it to be. When he said it was $60, that's when I knew.
    -Anthony Magagnoli
    Drive Faster Now
    Mar 2003
    somers,ny
    u could pull a handle from a card yes......but chances are youll bust the plastic post
    orrrr u could re melt it and kinda reverse engineer the surgery?
    Oct 2012
    Louisville, KY
    u could pull a handle from a card yes......but chances are youll bust the plastic post... orrrr u could re melt it and kinda reverse engineer the surgery?
    The tip of the post is flared by flattening it with a heated screwdriver blade, and the flare is less than the size and thickness of a dime. A flared post will not pull through the strong card material before breaking the post.
    To remelt and shape that flare back into being the tip of its post, using heated screwdriver blades, is unlikely. And then it will need to be flared again to reinstall the handle.
    Mar 2003
    somers,ny
    ahhhhh...I understand
    Dec 2020
    Charleston, SC
    97' BMW Z3 1.9
    Recently performed this trick with JB Weld epoxy. Hoping it will last a bit longer before complete failure.
    Greenville, SC
    Several
    A similar situation happened to the glovebox in my car after the evaporator was replaced. That lovely BMW plastic was on its last leg, so I had to find a replacement panel.
  1. wtb inner door pulls
    By eluther3z3 in forum Z3,Z4,Z8 Classifieds
    Last Post: 07-21-2013, 04:37 PM
  2. wtb inner door pulls
    By eluther3z3 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-21-2013, 04:26 PM
  3. wtb inner door pulls
    By eluther3z3 in forum Texas
    Last Post: 06-26-2013, 10:35 PM
  4. Small rip in leather door
    By sheps58 in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 10-16-2007, 09:21 AM
  5. wooden door pull needed
    By kosta in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-12-2002, 11:01 AM
