Results 1 to 10 of 10
Thread: M20 timing troubles
    Jun 2018
    Alabama
    1987 Bmw 325i
    Question M20 timing troubles
    Well let me say I am a total beginner. I just got my 1987 325i E30 a few weeks ago and I had no idea when the timing belt had last been changed. So I decided to do it myself I did the job fairly easily taking my time took about 5 and half hours again I am a beginner, but when I started the car it had a grinding noise from 1000 rpms to 1500rpms. This grinding noise isn't at any other rpm that I can hear. So any info on what that could be would be amazing thanks.
    Sep 2014
    KS
    e24e30e36e39e90
    Is that while you're sitting still revving the motor?
    Jun 2018
    Alabama
    1987 Bmw 325i
    Quote Originally Posted by sienayr View Post
    It happens both sitting still reving motor or driving at low speeds
    Jun 2018
    Alabama
    1987 Bmw 325i
    Could this happen if the timing belt is loose I have the car back apart only took 45 mins this time lol
    Sep 2014
    KS
    e24e30e36e39e90
    check your TDC marks to make sure everything is aligned properly. Easy to get one tooth off, although I don't know if that creates grinding noises or not. Try to figure out where the noise is from, a length of hose held to your ear while you probe areas of the motor can help locate the exact source of sounds. Like a stethoscope. They sell mechanic's stethoscopes at Harbor Freight as well.
    Jun 2018
    Alabama
    1987 Bmw 325i
    Thank you for the help turns out the belt was just loose
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    Which belt?
    Jun 2018
    Alabama
    1987 Bmw 325i
    Timing belt
    Apr 2015
    Toronto
    e30s
    I would recheck your timing marks..a loose belt could easily jump a few teeth.. If the belt does that rest assured you have bent valves.
    May 2010
    Officially in Tampa
    87 Cabrio & 87 ETA
    If a new belt is loose it's almost certainly because it wasn't properly tensioned and/or the tensioner wasn't tightened down (my money is on this).if so, as ceeker says, you may have done some damage.
  1. M20 timing belt change?
    By offthewall in forum 1988 - 1996 (E34)
    Last Post: 04-06-2008, 02:23 PM
  2. M20 Timing belt
    By mitster in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-20-2008, 06:22 PM
  3. M20 timing belt, to crank or not to crank??
    By acscnitzere34 in forum 1988 - 1996 (E34)
    Last Post: 02-19-2007, 03:01 AM
  4. M20 Timing..sputtering..uggh
    By AirDoc in forum 1983 - 1991 (E30)
    Last Post: 10-03-2006, 01:39 PM
  5. help. m20 timing belt problem
    By la-zdunck in forum 1983 - 1991 (E30)
    Last Post: 11-15-2005, 01:59 AM
