Results 1 to 7 of 7
Thread: Need help diagnosing lock/unlock "chirp/whistle"
    Overland Park, Kansas
    1997 BMW 840Ci
    The audible chirp/whistle stopped working some time ago. I've searched and searched here to get some guidance on root cause and fix but I've not found much at all. My question is whether anyone here has had that issue and if so, what's the solution?
    When locking with remote, the lights flash, just no audible.
    TIA for any help!
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    The siren which is stashed away under the dash area on the passenger side is accessible by removing the cabin filter housing and reaching into the void to feel for the fasteners. The battery inside often dies and corrodes requiring the entire unit to be replaced. That is the fix.
    What "thumbs up" really means
    1997 BMW 840Ci
    Thanks. I assume the siren uses coin cell type batteries. Those can't be removed and replaced?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    I think it is the alarm siren that makes the chirp - not the gong (which is for MID announcements) - the siren has moved a few times depending on model year, it was behind the RHS rear wheel arch at some point, but the ETK says it is behind the RH fresh-air duct. They usually use NiCad batteries which fail after a couple of decades....
    My BMW Repair YouTube Channel
    Mar 2011
    I don't believe the siren battery is even accessible. The unit is sealed (likely from moisture or for controlling the eventual leak). Would not be worth the trouble to seal back up properly.
    When I pulled mine out the wiring had melted at the connector and there was evidence of burning. I was able to repair it but ended up just disabling the alarm via fuse as the thing goes off constantly for reasons unknown. Would love to solve it eventually.
    CT
    '97 840CI
    I also have a '97 840 and the alarm is on the passenger side tucked away on this model. The weird issue I had was after locking the car, often the alarm would sound a few seconds later. Replacing the unit fixed that.
    Post from awhile ago. http://www.bimmerforums.com/forum/sh...ighlight=alarm
    (Are photos pulled from Photobucket now showing up?)
    1997 BMW 840Ci
    I spent all day yesterday detailing for an upcoming show Saturday. I decided to pull the alarm siren and opened it up. It is absolutely not designed to be serviceable and the battery connections are soldered in and corroded. So a new one on its way. Hopefully that will take care of it. $150+ when a few cheap batteries could fix it. Typical BMW... Just like the rear upper wishbones. Did an entire rear suspension makeover this spring. No bushings for those, $500+ each. Thanks to Wokke, new, and better bushings and good to go!
  1. need help with lock/unlock remote 99 323is
    By AndreyP in forum 1991 - 1999 (E36)
    Last Post: 03-25-2012, 03:12 PM
  2. need help diagnosing
    By biggie1784 in forum 1991 - 1999 (E36)
    Last Post: 05-19-2003, 12:14 AM
  3. Need help diagnosing a noise (m)
    By Fester in forum 1999 - 2006 (E46)
    Last Post: 03-31-2003, 12:40 PM
  4. Need help diagnosing fuel/ignition problem
    By traqrat in forum 1983 - 1991 (E30)
    Last Post: 10-03-2002, 03:12 PM
  5. Need help diagnosing misfire
    By melmyers12 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-19-2002, 02:35 PM
