Hi guys,
I was considering adding a tranny cooler since heat is the number one enemy of all transmissions. i believe these cars may already have a factory tranny cooler but i'm not sure.
I also dont want know i adding an after market tranny cooler may reduce the fluid pressure and cause other issues.
Does anyone have experience with this situation?
Thanks for your help
Not with an e38. I also have a 750 / 2000, so we are both post facelift. V8 and V12 e38’s have a ‘cooler’ plumbed into the radiator, let’s talk about this here, and see what develops - you are looking to insert a airflow based cooler?
Hi CPHES....yes I was considering the airflow based coolers but have some concerns about whether its necessary at all on the e38 since I think they have a factory cooler in addition to the radiator cooler.
What kind of cooler are you considering?
Also - as we look to add a cooler, there will be additional ATF needed -
Unless you're towing a heavy trailer you don't need anything additional to what came from the factory. Diligence with fluid and filter changes will server you better.
