Results 1 to 13 of 13
Thread: LSD diff not working - confirmation needed
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Local mechanic says LSD diff is not working on my automatic Z3 2.8 and sent me this video - turning one wheel while on lift and the other is not turning at all. Can you please confirm, that means LSD is not working and diff needs maintenance?
    Just want to be sure, that he didn't miss something (like checking should be done in gear only, or in neutral only or under load or something like that).
    P.S. There are no doubts that car has LSD diff - confirmed by VIN and by mechanic too.
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    I believe the non-M's have Torsen differentials.
    Due to the way a Torsen works, if there is no resistance on one of the wheels, it will not lock up.
    You can read more about it here.
    This ties into your locker question; the simple formula is that the high traction tire receives (up to) whatever amount the low-traction side can sustain, multiplied by TBR. So, T(high) = T(low) X TBR. This does necessarily mean that the Torsen requires some amount of reaction torque on both outputs to be able to act against. This is typically the result of tire contact with the ground.
    You probably see by now that in extreme situations, such as when a tire is lifted off the ground completely, that zero X TBR is still = zero. So, yes, in that case, the Torsen is limited.
    Therefore, the video that you have posted is not conclusive.
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Quote Originally Posted by scenturion View Post
    Any reference to source of this knowledge, please? I think some late production non-M z3 might have Torsens, according to this: https://www.bimmerforums.com/forum/s...5#post28931275
    But my car has clutch type limited slip diff.
    Nov 2016
    Oklahoma City, OK
    2000 BMW Z3 2.3
    This is the first I've heard of non-M Z3s getting anything but 25% Torsens, but my knowledge is not complete.
    Maybe the mechanic could drain the diff and slip off the cover to take a look? Nice opportunity to drain and replace the gear oil, if anything.
    edit: For what it's worth, RealOEM seems to indicate four different differential used in the 97 Euro Z3 2.8 at http://www.realoem.com/bmw/enUS/show...diagId=33_0385
    3,15 (33101428439)
    4,10 Automatic (33101428445)
    I=41:14=2,93 Hot climate manual (33101428435)
    3,91 Hot climate automatic (33101428437)
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Quote Originally Posted by Schreier View Post
    3,15 (33101428439)
    Car is not in workshop anymore. Wanted to confirm if I should order diff clutch parts for next visit in shop.
    That is US car (not Euro) with 4.1 diff (33101428445), options S209A (Differential lock %25) and S205A (Automatic transmission).
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    If you look at "Z3 E36 Z3 2.8 DIFFERENTIAL-LIMITED SLIP DIFF.UNIT" it shows a 25% lock up Torsen: http://www.realoem.com/bmw/enUS/show...diagId=33_1075
    I think they were also available with open differentials, however. If your car does have an LSD, it is almost certainly a Torsen as per the parts diagram.
    For reference:
    My 01 Z3 has a Torsen with 25% lock up: http://www.realoem.com/bmw/enUS/show...diagId=33_1075
    I confirmed this when I cracked it open and rebuilt it.
    My 99 M Coupe has a 25% lock up clutch type: http://www.realoem.com/bmw/enUS/show...diagId=33_1075
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    For reference:
    You might be right, couldn't find that diagram... Maybe it is Torsen then. Thanks!
    Mar 2004
    San Diego
    2000 Z3 2.3, 2014 M235i
    For reference:
    I think the early Z3s had Clutch pack LSDs, in 99 or something they switched to Torsens. I don't recall when the switch happened, but I do recall some of the early ones had clutch ones. It should say it on the diff itself, if it is something like S315 or whatnot.
    edit:
    For a 97 Z3 2.8, REALOEM lists it as a Torsen 25% as well. So maybe someone has more detailed knowledge, but if that is the case, you also prolly have a torsen.
    Suspension: Bilstein Sports, GC Coilover conversion, IE Subframe Bushings, IE RTABs, M roadster sways, M roadster front control arms, M roadster Front calipers/hubs.
    Engine/Driveline: M54B30 intake Manifold, Dinan CAI, ZHP Cams, Headers, Underdrive pulleys, Conforti Software, 3.46 diff.
    Oct 2008
    SFBay, CA
    02 LSB Z3M Coupe
    Quote Originally Posted by deni2s View Post
    On the plus side, this means that your diff probably works great. The clutch type wears pretty quickly, but the 250k mile torsen in my Z3 still works like a champ!
    Dec 2011
    Riga, Latvia
    2x 1997 BMW Z3 2.8
    Yes, agree.
    Tim @ BMW of Dallas
    98 Z3 2.8
    Both my 7/98 and 10/98 build non-M's have Torsens that work great.
    96 320i Touring
    98 Z3 2.8 Roadster
    01 PY M Coupe
    96 Z3 1.9 - DASC
    95 318ti Clubsport
    94 Miata M-Edition
    13 smart fortwo
    los angeles
    '01 Z3 Coupe, '91 318i
    Aug 2017
    My 12/98 build non-M Z3 has no locking differential at all, according to a VIN decoder and turning the wheels.
  1. headlights not working correctly, need facelift LCM
    By bigjoe87865 in forum 1996 - 2003 (E39)
    Last Post: 01-13-2016, 04:00 PM
  2. E38 some gauges not working i need help
    By rome190 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 06-09-2014, 08:32 AM
  3. Fuel gauge does not work properly...need help
    By Bimmerman44 in forum 8 Series (E31)
    Last Post: 05-28-2014, 04:31 PM
  4. Horn not working, help needed
    By randomy in forum 1991 - 1999 (E36)
    Last Post: 04-04-2009, 02:35 PM
  5. Need HELP ! Temperature Control Module not working
    By JLee in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-04-2001, 04:07 PM
