Results 1 to 9 of 9
Thread: rattling noses in 3rd and 5th gear
    Nov 2012
    CA
    96 318ti
    Today my car started to give a rattling noise in 3rd and 5th gear. Basically, when my shifter is forward. I can feel it slighting in 1st gear too...but it's noticeable in 3rd and 5th only.
    I pulled the tranny fluid, fearing that it might be low for some reason... everything was normal.
    My shifter does exhibit some play, but I dont know if its outside of normal tolerance or not. I just hope it's not my flywheel. What do you guys think>?
    DIY 96Z3 (M44): Drive Belts, Starter, H2O Pump
    DIY 00ZM (S52): Gauges: clock, battery, oil
    Sep 2017
    California
    1998 e36 328is
    Guibo (flex disc) ?
    Jun 2005
    Concord, NH
    08 E90M3; 99 E36M3 Turbo
    If something is loose enough to rattle inside your trans, there is nothing you can do other than buy another trans. What you are gearing probably is not that. Certainly look at your linkage, but remember that NVH travels and varies with rpm and speed. Could be a lot of things between the motor and the differential, but I agree with looking at the driveshaft first. Rubber coupler up front and rear u-joint if you have one (some have a CV joint). Id also look at the motor mounts, trans mounts and diff mounts. And exhaust and heat shields.
    Jul 2005
    Indianapolis, USA
    1997 M3
    Is it the heat shield rubbing on the shifter by the driveshaft? Climb under the car and take a look.
    Nov 2012
    CA
    96 318ti
    i dont know if this is the problem, but there's a ring that slipped off its rubber cushion on my driveshaft. It's where the driveshaft meets up with the tranny. It might be #2 (http://www.realoem.com/bmw/enUS/show...diagId=26_0284)
    May 2012
    North central Iowa
    '94 325i, '93 325is
    Some people remove the whole part #2. Some driveshafts have them, some don't. It isn't necessary as far as I know.
    '93 325is Coupe, Schwarz, work beater 288k
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k
    '85 Toyota LandCruiser: Lifted, gas hog. 202k
    '99 Nissan Maxima: 5spd, Rusty but trusty winter beater. 252k R.I.P.
    Nov 2012
    CA
    96 318ti
    i had a wild experience while driving the car last night, the rattling got so bad where I could feel something hammering against something. Moreover, I was not able to take my car out of gear while in motion. I dont know if my experience is related to this worn out part or not, but I would like replace it to see. Today my car is acting completely fine...
    i just hope its not the clutch bearing.
    Oct 2012
    Detroit, MI
    98 323is, 08 X5 4.8i
    Since you haven't confirmed that it isn't the problem, I'll say guibo again.
    Nov 2012
    CA
    96 318ti
    Thanks. Ill replace that too then. Ive order both parts.
    In the meantime, ive hammered the broken parts back together as much as possible. So far all is well
  1. 5-speed wont shift into 3rd or 5th gear
    By pino635csi in forum 1976 - 1989 (E24)
    Last Post: 11-19-2015, 03:36 PM
  2. E46 stuttering in 3rd, 4th, 5th gear
    By pete318is in forum Southwestern - US
    Last Post: 08-16-2010, 01:07 PM
  3. Replies: 1
    Last Post: 01-06-2010, 04:36 PM
  4. Cold Transmission 3rd/5th gear vibration
    By kornkid8600 in forum 1991 - 1999 (E36)
    Last Post: 11-19-2009, 01:45 AM
  5. 3rd and 5th gear in my 03 330ci..Issue?
    By ericmichael in forum 1999 - 2006 (E46)
    Last Post: 12-27-2008, 09:58 PM
