Results 1 to 18 of 18
Thread: Pre 1997 M73 ECU tuning
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Issue is that 1995 1996 M73 came with the DMEs with 1 time write chips... has anyone had any luck to remove oem chips and install flashable chips?
    Nov 2007
    Belgium
    Made in Germany
    Get in touch with firebird540. He's one of the authorities on 850Ci M73 tuning.
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by revtor View Post
    Thank you will do.
    Nov 2013
    Whitney, TX
    97 850CI
    Quote Originally Posted by dragon850 View Post
    Thank you will do.
    Hey Dragon. Please let us know if you have any luck with firebird, as I am also interested.
    Desecrator of all things Sacred
    UAE
    Merc R129, E31, Jag XKR
    +1...im interested too! 95 M73
    Has anybody spoken to DUDMD?
    "Understeer is when you hit the wall with the front of the car, Oversteer is when you hit the wall with the rear of the car, Horsepower is how fast you hit the wall, Torque is how far you take the wall with you."
    Nov 2013
    Whitney, TX
    97 850CI
    Quote Originally Posted by spitfire980 View Post
    Yes. He doesn't offer programming for the M73.
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Yeah he does? He owns one of the baddest 750iLs out there. He’s got videos of him tuning it on his website and offers tuning for M73 cars that you can buy right off the page.
    UAE
    Quote Originally Posted by 72tpik5 View Post
    https://www.dudmd.net/products/750il...rformance-tune
    https://www.bimmerforums.com/forum/s...-tune-rocks!!!
    All of them are for the E38 though, dont know if he does the E31
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Lie I said guys, the tuning is for post 1997 M73, earlier versions have a one time write chip. That is the problem I am trying to solve.
    UAE
    Seems you are right, I asked him on FB, here is his reply:
    "Cannot tune the pre 97 at the moment. No hardware available to replace the current eprom"
    If you do find anything, count me in
    Mar 2016
    Tyler, TX
    1992 E31 850i
    How hard (or expensive) is it to run a pre-97 engine using a post-97 ECU with the modifications you want? I'm just wondering whether junking the entire computer and replacing it with another tunable one (or two or three, with the V12) gets you to your destination. Used units are all over eBay, assuming you can identify one with the reusable chips.
    Cheers, John
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Quote Originally Posted by dukegrad98 View Post
    Cheers, John
    Not possible, different harness and ews 3.
    Can anyone open pre 1997 dme and send me the pic of the chip? I don't have the car here
    Nov 2013
    Whitney, TX
    97 850CI
    Quote Originally Posted by killian665 View Post
    Since we are on the E31 forum, I assumed you would understand that we were talking about the E31 M73. My mistake.
    UAE
    What ever happened to this? any updates?
    Oct 2002
    Cold Snowy North
    Misc.
    Last I heard no
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    The update is... you cannot do much at all to M73 powered E31's.
    Oct 2002
    Cold Snowy North
    Misc.
    In a bit more detail, as far as I know Firebird is the only person who has been able to do any type of mods to the DME. I don’t know of any third-party that has been able to replicate his work.
    I have also heard whispers that there is at least one E31 M73 running a completely custom engine management system, But never seen any independent proof.
    The only other engine modification is the ‘Dinan’ Intake manifold extruding/hone to supposedly improve flow and give HP…. Even though it’s very well established that the flow limiting /bottleneck of the M73 head is the exhaust valve / port design…not the intake side.
    San Ramon, CA
    850Ci, M5, Model-S P85D
    Any ideas on how to upgrade or program the E31-M73 AT-EGS?
    I believe "Firebird540" did the DME and EGS upgrades whey back when, however he lives in Germany and only did the upgrades in person when he came to Las Vegas.
    Post:
    http://forums.bimmerforums.com/forum...3#post25913483
    I think BMW extracted just about all the torque/HP out of these 2-valve engines, however a 3.23:1LSD does wonders for rear wheel torque with only a minor RPM increase.
    Personally, I would like a transmission "Sport Mode" M/S-Gate gear selection program update for the E31-M73.
    1) M/S-Gate selection for 1st gear.
    2) M/S-Gate Sport mode that uses 1st - 4th only.
    E38-M73 and E31-M62 has the M/S-Gate but the E31-M73 only has an M-Gate.
    The AT-EGS control units are all "GS: 9.22.1" with the E31-M73 "Code: NW" and the E38-M73 has a "Code OF"
    Unfortunately, that I'm aware the EGS is not programmable in the car. I swapped an E38-M73 EGS into my E31 and it causes a Trans Program Fault.
    I anticipate the hand-shake fails!!
    Current E31-M73 transmission program cannot manually select 1st gear.
    No Sport Mode selection with M/S-Gate; so the transmission normally shifts 2nd - 5th gear (aggressive throttle position at start-off will induce a head snapping 1st gear down shift at start off)
  1. ECU "tuning" for Euro 3.2L?
    By E368 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-21-2007, 11:36 AM
  2. Stand alone ECU tuning
    By KAMIKADZE in forum Forced Induction
    Last Post: 02-01-2004, 05:40 AM
  3. AA ECU Tuning
    By subpilot in forum Forced Induction
    Last Post: 07-21-2003, 01:23 AM
  4. OBD II turbo ECU tuning by mail.
    By Cheuk in Seoul in forum Forced Induction
    Last Post: 02-28-2003, 11:08 PM
  5. 1997 M3 ECU & Wiring Harness
    By Fknfastm3 in forum BMW Parts For Sale
    Last Post: 02-10-2003, 12:57 AM
