Results 1 to 11 of 11
Thread: FS 1980 320i Sport model
    Corona California
    79 320/6 81320i 65malibu
    1980 BMW 320i Sport Model $5,650 firm - If you are into DIY body work and paint then this could be the car for you, drive it through the week and sand it on Saturday.
    This is an original sport model with all the original sport up grades and two way operation sun roof that we have owned since 1989. Car has sat un-driven for the last 2.5 years as it had a bad head gasket. Now has different block and head. Bring pickup truck for original cloth rear seat and other extra parts?
    Just passed smog 6/8/2018 registration good till April of 2019. Car starts well hot or cold and runs smooth and quiet down the highway and around town. Will need head re-torqued in about 575 miles or so. Depending on the miles I put no it before it sales.
    I have done a lot of work preparing this car for sale - I have pictures of more of the work.
    I have listed as much as I can think of -
    MISSING Sport edition parts:
    *13” BBS basket weave wheels
    *Leather shift knob - NOT INCLUDED – died long ago”
    Sport edition pieces Included:
    *Recaro Sport driving seats
    *Three spoke sport steering wheel
    *5 speed overdrive tranny
    *Leather shift boot
    *Larger 28mm front sway bar (anti-roll bar)
    *19mm Rear sway bar – up graded with polyurethane link ends
    *3.91 LSD rear diff - rebuilt
    *Trunk lid badge delete
    *Large tool kit in trunk
    *front BBS air dam currently off car
    Up-grades, Mods and rebuilds done:
    *LSD in diff rebuilt with new clutches and drive plates – extra shims added for more initial lock-up
    *Diff has new pinion bearings, all new seals, new pinion crush sleeve, new pinion nut lock and filled with Redline 75w90ns syndetic oil.
    *Fuel Distributor “air flow meter” upgraded to one off 2.0lt engine
    *Super tucked front bumper – bumper was trimmed thinner and mounts to shocks trimmed as well as shocks shortened.
    *Bilstein Sports front and rear
    *Adjustable coilovers front and rear – 325lb 8” Eibach springs in front with 12” 120lb springs in rear.
    *Hartge H3 aluminum front strut tower brace
    *Original Ken Danielson rear strut brace with battery mount
    *Battery relocation to trunk with “00” gauge cables
    *Stainless Steel brake lines
    *Made and installed ¼” thick polyurethane washes to set position of front control arms to sway bar.
    *Drilled front rotors
    *Polyurethane filled rear subframe mounts
    *Polyurethane steering rack mount bustings
    *ALL FOUR - CVD’s cleaned and refurbished with new grease and boots
    *New carpet in the interior
    *Sound deadening in interior refurbished
    *New carpet in trunk
    *New trunk plywood spare tire cover
    *New Old Stock OEM front Valiance
    *New clutch master and Slave cylinders
    *Refurbished head
    *New Head gasket
    *New vacuum lines on engine
    *New spark plugs
    *New coil
    *Replaced original front fenders with better used ones and prepped and rattle can painted
    *Rolled / Flared rear fenders for 8” wide rear tires
    **Lots of rust repair in trunk and at weather stripping – rust kill, fiberglass fill, sealer, primer and painted. Then seal re glued in place.
    NEWISH PARTS with 3,000 to 6,000 miles on them:
    *Plug wire along with cap and rotor
    *2.5” high flow cat
    *Oldman stainless steel exhaust down pipe
    *2” exhaust and Dynomax turbo muffler
    *New Injectors less than 3,000 miles
    *Surfaced fly wheel
    *Clutch & pressure plate
    *Refurbished Fuel Distributor – 3,000 miles
    *Rear wheel bearing – 8,000 or so
    *Brake master cylinder and booster
    *External fuel pump and filter
    *High pressure breaded fuel line from chassis to fuel distributor on engine
    *center carrier bearing on drive shaft
    The Bad:
    *Needs windshield replaced after paint
    *Still has original Polaris Silver factory paint. Clear coat going or gone needs minor body work to fix surface rust then paint
    *AC has been deleted long ago – which to me is a plus due to the weight removed.
    *Seats need reupholstering
    *Dash cover is cracked
    *Dash panel near light switch cracked
    *Headliner is shrinking away from roof
    *Heat core needs replacing – leaks inside car
    *Have original Blaupunkt radio/cassette but out of car
    *Some side molding off car (need new clips) – no need to install till after paint
    *13” steelies are rusty
    *Heater control doors in assembly not working with cables
    I am in no hurry to sell it.
    Attachment 631539 Attachment 631540 Attachment 631541 Attachment 631542 Attachment 631543
    Will try and post more pictures later need to let the forum reset it's self.
    Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
    Corona California
    122 views and not one "your crazy" I know you are thinking it . . LOL
    I know was looking for feed back and open discussion on e21 parts / car values.
    Portland, OR
    1982 323i 2003 325it
    Quote Originally Posted by OLD MAN View Post
    162 views and not one "your crazy" I know you are thinking it . . LOL
    with my limited knowledge on e21s (still learning), i feel like you're pricing is pretty spot on for a tastefully modified and structurally sound car. I believe the only thing that will turn people off is the "BAD" of the car. the good is really good, but the bad is a bit more than the average wrencher would want to undertake. That being said, I feel like its a great buy, and anyone who would entertain the idea of owning it would never be disappointed... until it gets into the 90s 100s in SD, like i know it can!
    Good luck, Daryl, its a great car!
    Past, Present, and Future
    1974 BMW 2002tii (RIP)
    1995 BMW 325is w/ FULL S50 swap, track prepped (SOLD)
    1988 BMW 325ix Zinno/Black (RIP)
    1988 BMW 325ix Alpine/Black (Sold)
    1988 BMW 535is Alpine/Pacific Blue (Going Away...)
    1982 BMW 323i (Current Project/Paper Weight)
    2003 BMW 325i Sport Touring (Daily Driver)
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    Yes, Good Luck with the sale.
    Randy
    Corona California
    Thanks Morty and Randy.
    It is defiantly a project car as far as the body work goes, and I have done body work in the past - track car for one - and total paint jobs. But the chassis / unibody is in good condition most of the damage is do to the sun. But for now it is time to down size and think about the next 10 years and where we want to live.
    Morty do you go to BMWCCA San Diego events?
    Portland, OR
    I did when i still lived in SD. Moved home to Portland when i got out of the Navy in 2011... The CCA events up here don't seem nearly as fun to me as they did down there. Went to a couple of events, but they just didn't grasp my attentions as they did down there.
    Feb 2016
    Sacramento, CA
    1979 E21 320i
    Do they do them at Qualcomm? Or whatever it is now
    -John
    Portland, OR
    Quote Originally Posted by Somjuan View Post
    Yessir! At least, that's where they did it when i last AutoX'd there in 2011...
    Corona California
    This is the last year at Qualcomm as the city is going to decommission it. Most likely put up more condos or something.
    Vermont
    81 320i, 98 318ti
    That is a great solid car, I know it very well! Good luck with the sale, Daryl.
    Max
    Corona California
    Thanks Max - hope you are doing Great!
    Anytime Auto-x going on back in your area?
  1. FS: 1980 320i Sport model, LSD, Recaros, rear sway bar stock
    By OLD MAN in forum 3 series & Z Series
    Last Post: 12-18-2009, 10:03 AM
  2. fs: 1980 320i $500 Socal
    By Jesse30 in forum 1975 - 1983 (E21)
    Last Post: 01-01-2008, 05:33 PM
  3. FS: 1980 320i, White, Very original, Bay Area
    By sfracerdan in forum 3 series & Z Series
    Last Post: 09-14-2007, 12:12 AM
  4. F/S 1980 320i Sport
    By bread320i in forum BMW Cars For Sale / Wanted
    Last Post: 01-08-2006, 10:34 PM
  5. FS: 1980 320is w/ good stuff
    By nexus in forum 1975 - 1983 (E21)
    Last Post: 03-01-2005, 05:11 PM
