Results 1 to 13 of 13
Thread: Offset FCABs vs AKG Really Offset FCABs
    Jun 2004
    NNJ
    04 330xi, 98 M3/4/5
    It is fairly plain to see in photos that the AKG FCABs are drilled offset another few millimeters out from the normal offset FCAB location (which is something like 16mm off center IIRC).
    Anyone have any post-install caster data and/or photos with the AKGs?
    Any idea how much additional caster you gain with these over standard offset?
    Trying to sort out my options... track only car except bedding brakes and occasionally driving to the event.
    [2004 330xi/6] Orient/Natural :: 117-142k :: ZSP :: ZPP :: ZCW
    [1998 M3/4/5] Cosmos/Black :: 113-125k :: TCKline D/A (500/600) :: GC Plates :: RD Sways :: GC Rear Arms :: ZHP Rack :: 3.64 Diffsonline :: PF FCAB :: BW RTAB :: AKG Subframe :: TMS Pulleys :: AA & Borla :: XBrace :: TRM C2s :: BW lines :: DTC60 :: Safety Equipment
    Past:
    [1995 M3] Avus/Dove :: 141-242k :: S52 OBDI :: M50 manifold :: 3.5 HFM :: Turner Chip :: XBrace :: SS Lines :: Turner RTABS :: Vogtland CS :: Bilstein Sport :: Z3 rack
    [1999 M3] Cosmos/Black :: 65-87k :: TCKline S/A (400/500) :: Turner plates :: UUC Front Sway :: PF RTABs :: AA Intake :: Borla :: XBrace :: TRM C2s :: CL RC6E :: Safety Equipment
    [1993 325is] Brilliant/Black :: 135-139k :: Bilstein sports :: Eibach sways and springs :: Dinan camber plates and chip :: Borla :: LSD
    [1983 320i] Safari/Brownish :: 219-242k :: homebrew CAI :: some rust :: multicolor body panels
    Oct 2003
    Seattle
    99 M3
    Depends what model year you are driving. The Spindle(King Pin)/FLCA/FLCA Bushings/Strut Mounts we’re redesigned for 1996+M3.
    May be acceptable for 1995M3 geometry.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    There are also SLR adjustable eyeballs.
    Jun 2004
    NNJ
    04 330xi, 98 M3/4/5
    Quote Originally Posted by bluptgm3 View Post
    98 M3 with 95 geometry Meyle arms (usual Bimmerworld kit). TCKline D/As with GC Race camber plates.
    I'm sure they are "acceptable" otherwise AKG wouldnt sell em. Just wondering real world numbers.
    I think full-on spherical mounts might be a bit much until i trailer the car everywhere.
    Past:
    Aug 2013
    1999 BMW M3 Coupe
    Nah, the car would still certainly be civilized enough to drive to/from the track. It's not nearly as bad as putting in solid driveline mounts, a racing clutch or lightweight flywheel, or a number of other "because racecar" things you can do. There's some crazy people who use those eyeball things on street cars, though I definitely don't suggest that.
    Anyways, point is the spherical mounts are something you should seriously consider for a car which is primarily tracked.
    Jun 2005
    New England
    They aren’t bad. I have been using them for a couple of years and drive about 8k per year. Depends on how the hard core you want. Fresh stock suspension is pretty supple and you start losing that when you mod it. The delrin you are considering is not exactly compliant. It’s pretty close to solid.
    Jun 2004
    NNJ
    04 330xi, 98 M3/4/5
    How much castor did you dial in with them
    Past:
    Jun 2005
    New England
    As I recall, I can’t get as much positive castor on my car as is recommended for best handling. I do have vorshlag plates but have really only played with camber and mostly to minimize it. Maybe my issues are due to an accident in 99. I tried to adjust the SLR eyeballs as close to 96-99 spec as I could get. I have 255/40 fronts on 17x9 and would rub with 95 spec. I have an alignment somewhere but just moved so I am not likely to find it anytime soon.
    Jun 2004
    NNJ
    04 330xi, 98 M3/4/5
    Gottchya. With the 95 geometry arms I should be fine with normal offset, just wanted real numbers on the Akgs.
    Anyone with SLR or AKG sphericals... do you need to press them onto the arms as opposed to BFH?
    Past:
    Apr 2016
    Irvine, CA
    99 328is, 03 X5
    BFH works.
    I run the SLR adjustables on my dual purpose car, as they allowed me to even out the caster (+6.5) side to side. More is possible, but this is what I prefer.
    Jun 2005
    New England
    How does the caster adjustment through the SLR work? I thought caster was forward and backward. The SLR can be adjusted sideways.
    Oct 2003
    Seattle
    99 M3
    The FLCAs pivot about a point on the subframe - Adjusting the aft end of the FLCA outboard moves the King Pin pick-up ball joint forward (and inboard).
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by NotUrAvgM View Post
    The geometry of the 1996+M3 King Pin/Spindle with 1995M3 (318/323/325/328) FLCA can be corrected with Camber Plates.
  1. 95 M3 Offset LCAB vs. 96+ LCAB
    By PJ Steamboat in forum 1991 - 1999 (E36)
    Last Post: 10-30-2008, 04:30 AM
  2. 2.8 vs. M Roadster offset
    By Hobbs64 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-22-2005, 10:59 AM
  3. 20 mm vs. 40 mm offset?
    By Puzzled1 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 06-07-2005, 05:39 AM
  4. E31 vs E34 Wheel Offset
    By dternst in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 10-04-2004, 06:44 PM
  5. E31 vs E34 Wheel Offset
    By dternst in forum 1988 - 1996 (E34)
    Last Post: 10-02-2004, 03:09 PM
