Results 1 to 25 of 66
Thread: E36 m60b40 HX40 v8 Turbo on going
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    My car is e36 with next mods:
    1. Engine v8 m60b44.
    2. Holset hx40.
    3. Ecu invent.
    4. Audi rs6 coils with cold spark plugs NGK.
    5. AFR AEM.
    6. Intercooler GREDDY.
    7. EGT
    8. K&N filter
    9. Aem fuel pump
    10. 440cc injectors
    11. Etc etc etc
    All wiring almost done and soon first run. Also, i have water to air intercooler which i can instal here. Now, we planning to start with 5-7psi. With 4.4l engine hope i can achieve about 400whp. My goal is safety and something about 12-13sec 402m or 9sec 100-200kmh. Any recommendations or advises from you will be appreciated.
    e39 540i 6speed Supercharged,
    E36 v8 m62 with m60 headers, Turbp HX-40 0.6-0.5bar or 9psi, custom exhaust & Turbo manifold, injectors 440cc, ECU Invent EMS-2, Mishimoto Intercooler and oilcooler, etc…
    Nov 2013
    Gerrrmany
    E21 M50 Turbo
    Looks good. Watch out that you dont run out of injector capacity with those 330cc ones.
    AND do your best to heat shield that exhaust housing. Looks like trouble already.
    1982 E21 323i
    M50B25 Turbo
    Borg Warner S362 SX-E
    ECU Master Emu
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    We calculated it, looks like it has the ability to give about 430WHP. If I will be out of injectors specs, then will add additional injector or change to bigger one.
    Quote Originally Posted by PowerKraut View Post
    What does it mean, can you please explain with more details bro, I am not English native.
    Nov 2013
    Gerrrmany
    E21 M50 Turbo
    Watch out that your turbo does not burn and melt your wiring not a native speaker either.
    1982 E21 323i
    M50B25 Turbo
    ECU Master Emu
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Catched, that is just prestarting wiring and soon there will be no any wirings.
    We just burnt coil drivers on ecu. To run bmw coils we had to put additional drivers, but when we purchased ecu, seller said that we do not need those drivers. Now we know he was lying.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Today we trying to adjust starting point from 1st cylinder. Hope soon we will be able to drive.
    Apr 2006
    Minnesota eh?
    86 325es
    Creative turbo placement. I would recommend you put a turbo blanket on and maybe also a vent in the hood.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Yes bro, i prepared special cover for it. If it will not protect, then i will consider blanket.
    Yesterday we tried find ignition point on first cylinder. Something went wrong. Trobascope does not flash in point where it should.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Today we managed finally run engine first time.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Some new photos.
    20180906_195213-1280x720.jpg20180906_195204-1280x720.jpgIMG-20180906-WA0015-720x1280.jpeg
    Currently working on AFR and trying to work engine work smooth. AFR is 17. Engine works and soon will go for tests on road due we have no dynostand.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    We made house keeping and put all wires in place. Couple of days and we ready to onlinetuning.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Gents, i have a problem. When i instal afr 14.7 car is working with shaking. When i put afr 12 the engine works smooth. Both headers goes to turbine then there is installed afr after 25 sm.
    Any idea?
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Here is attached my coils and its program data. We think that we give wrong numbers. If someone knows what numbers should be in inductance-resistance-peak current, i will appreciate.
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by dovlet View Post
    Any idea?
    Do you have an air leak before the turbine? Can you recalibrate the sensor? If it doesn’t want to run at 14:1 then most likely the sensor is not reading correctly. Have you driven it? How does it react to different AFR when driving under light throttle?
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Bro, we do not have any air leak. I did not know that AEM AFR should be colibrated. How shall i do that collibration? We did not run yet. Just 20m. When we put afr 12 it works very smooth. Today we will try put different afr aem sensor.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Dover: Usually there's a procedure to calibrate the WBO2 with the software/device that you're using, should be explained in the documentation. Basically normally its something to the effect of "put the sensor in free air, click the WBO2 calibrate button / menu choice / command".
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Today i will do it. But, aem is saying do not need to do any colibration for 4.9LSU. Thanks man, will try
    Mar 2010
    Well in theory brand new sensors are tested and calibrated from the factory, so you wouldn't need to re-cal until the sensor is aging. Theory doesn't always match reality tho... if the software has the function it might be worth doing anyway.
    2003 M3CicM6 TiAg
    Former:
    Mar 2010
    Dove, when you say "you put AFR to 12" do you mean that's the fuel quantities you're specifying in the open loop base injection tables? Or do you mean the gauge is reading 12:1? What is your gauge reading in Lambda (I assume you can change to lambda display?)
    It could very well be that your fuel needs to run richer than ideal pump gas AFR's (aka 14.7:1) to run OK. But in Lambda your target is still going to be 1.
    For those who are new to Dovlets party - his gas can often be questionable. Wouldn't be out of question for it to have some solvents or other distillates snuck into it.
    2003 M3CicM6 TiAg
    Former:
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    I meant afr numbers, i can put my standalone to auto mode, then it keeps injectors in position to supply 14.7 oxygen to 1 gas. If i put 12:1 then opening time for injectors increasing. Now i have engine smooth with 12 oxygen to 1gas. I have no lambda.
    Yes, gas is still a problem)))
    Toronto, Canada
    E36 Turbo
    There is no free-air cal. on AEM units... it's done by the cal. resistor on the O2 sensor.
    As for running smoother at a lower AFR... that is pretty normal if the car isn't well tuned. With zero information being provided it's impossible to tell what is actually the cause.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Quote Originally Posted by NOTORIOUS VR View Post
    I can give any specific info, just let me know exactly you want.
    Toronto, Canada
    E36 Turbo
    I detailed log from the ECU would be a good place to start. Maybe even a video showing the difference between lambda 1 and say 0.85 lambda (12.4 AFR)
    Also are you reading the AFR directly from the gauge or from the ECU (via analog output of gauge via input to ECU)? if reading from ECU, please remember that ground for AEM gauge needs to be connected to ECU sensor ground to make sure there is no (ground) offset present!!
    Jul 2005
    California
    Bima
    if u had the 14point7 wideband you can calculate the grounding offset out.
    just sayin.
    Feb 2016
    Ashgabat
    e36 v8 Turbo HX-40
    Aem grounded to cat itself. We are monitoring both, aem gauge and ecu data in lap top. Both of them are same. You still wants me to reground my ground to ecu?
    Logs will be provided soon.
  1. E36 1997 e36 328i with v8 swap trade for 240sx NEED GONE ASAP
    By nickmerrone in forum 3 series & Z Series
    Last Post: 04-04-2013, 12:29 PM
  2. E36 wtb: e36 m3 looking for turbo compatible engine components
    By gev18 in forum BMW Parts Wanted
    Last Post: 12-03-2012, 02:07 PM
  3. E36 WTB: e36 m50 supercharger kit/turbo kit
    By r0meyrome in forum BMW Parts Wanted
    Last Post: 12-26-2011, 06:24 PM
  4. E36 E36 race car V8 project 4 sale
    By aussiebj in forum Race Cars & Track Parts
    Last Post: 05-29-2011, 08:22 PM
  5. E36 E36 m3 fully built turbo engine for sale
    By ARD in forum Engines, Performance Parts & Software
    Last Post: 05-17-2011, 11:12 AM
