Results 1 to 22 of 22
Thread: e46 320d 110kw underboost cant find problem
    Jun 2018
    Lithuania
    E46 320d 110kw
    Having issues with my turbo, when accelerating feels like car has only like 60-80 kw some times better some times worst and 1 out of 10 times when accentuating power comes back like it should. its very weird. Inpa live data shows that that turbo is under boosting.
    what i have checked is that turbo actuator is moving freely and has correct amount of movement.
    Solenoids are working. switched with egr's solenoid no effect.
    EGR cleaned.
    Fuel consumption completely normal. Maybe clogged exhaust?
    providing link with inpa live test on road.
    Maybe MAP, MAF >?
    Fuel injector ?
    https://youtu.be/PAnMCBdjbeA inpa live data
    Jun 2018
    Lithuania
    E46 320d 110kw
    https://youtu.be/p_zGpxAqm2s turbo actuator rod movement
    Jun 2018
    Lithuania
    E46 320d 110kw
    2002 years e46
    Mar 2015
    west chicago il
    01 E46 330i 5sp man spor
    Any smoke from exhaust? If so what color.
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Jun 2018
    Lithuania
    E46 320d 110kw
    No unusual smoke.
    Jun 2018
    Lithuania
    E46 320d 110kw
    Turbo axis doesnt have bad movement back and forth, has only like 1mm movement from side to side
    Sent from my MI 5s using Tapatalk
    Mar 2015
    west chicago il
    Have you checked for a boost leak?
    Jun 2018
    Lithuania
    E46 320d 110kw
    Inspected by hand, intercooler hoses looks fine, no whisle noises while accelarating
    Jun 2018
    Lithuania
    E46 320d 110kw
    How to tell if map or maf is good or bad in my situation. Disconnecting maf makes it little worst
    Jun 2015
    Cape Town, South Africa
    2001 bmw 320d
    Hi. Have you removed inlet manifold? Oil in pipes?
    Sent from my LG-H990 using Tapatalk
    Jun 2018
    Lithuania
    E46 320d 110kw
    Whel the intercooler pipes has some soil, but how much is bad, what that would indicate, havnt removed manifold. Should i, though?
    Jun 2015
    2001 bmw 320d
    Had issue with contaminated manifold pressure sensor. Unplugging mass did not provide performance improvement.
    Jun 2018
    Lithuania
    E46 320d 110kw
    Cleaned map sensor, zero improvement
    Mar 2015
    west chicago il
    Low power and boost could be from inadequate fuel supply. Not sure if this engine monitors fuel supply pressure and would give a code for low fuel pressure. We don't have diesel e46 in the USA. Gas e46 fuel pumps are a common problem. Not sure about diesel models though. Point is check fuel pressure. Could be clogged filter or bad pump.
    Jun 2018
    Lithuania
    E46 320d 110kw
    Cant see how it can be fuel related problem, becouse inpa shows low turbo pressure in live data.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What are the codes? You need to scan the engine computer (DDM in BMWspeak) and the automatic transmission computer (EGS) for codes. Also, get the OBDFusion app for your smartphone or or tablet. Then, go to E46Fanatics and search for threads on OBDFusion in which jfoj has commented. He’s the guru. His comment will tell you which interface adapter you need to buy (it plugs into the obd2 port), how to set the app up, and how to use it.
    Jun 2018
    Lithuania
    E46 320d 110kw
    4530 code
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Is that a “P” code?
    Jun 2018
    Lithuania
    E46 320d 110kw
    Code 4530: Charge pressure control error / TCU pos / Air-filling control / Air charge control, anomaly / Air-filling control, deviation / Air-filled deviation
    Mar 2015
    west chicago il
    Quote Originally Posted by snopd View Post
    It takes fuel to make power and boost.
    Jun 2018
    Lithuania
    E46 320d 110kw
    But but inpa shows low boost, and the code says problem with boost not the fuel pressure , or should i still inspect fuel ?
    Jun 2018
    Lithuania
    E46 320d 110kw
    If you checked inpa live data video, you can see that railpressure is ok.
  1. E46 320D 110KW what is the sound
    By slafino in forum 1999 - 2006 (E46)
    Last Post: 05-31-2017, 01:55 PM
  2. E46 320d 110kW manual - Low boost pressure (INPA video inside)
    By martinlink in forum 1999 - 2006 (E46)
    Last Post: 01-07-2015, 07:04 AM
  3. 2005 BMW e46 320d Fan Problems, Pls Help!
    By rask3t in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-30-2008, 09:20 PM
  4. Auto transmission problem dealer cant find
    By lbsohk in forum 1996 - 2003 (E39)
    Last Post: 09-01-2007, 10:28 AM
  5. BBIIGG PROBLEM!! cant find it..
    By mifslim in forum 1991 - 1999 (E36)
    Last Post: 04-03-2007, 06:05 PM
