Results 1 to 16 of 16
Thread: Going lean. pump or injectors? e85.
    Jul 2005
    California
    Bima
    wtf lean by jet jones, on Flickr
    So as you can see i'm at about 14.5 afr @ 6,000 rpms on 17psi. it's a m30b35 with a turbo cam from cat cams and big ring gap.
    it's using an intank walbro 255 stock wiring and seimens 80lb injectors.
    This is not a final tune. just taking it out on e85 see how it goes. usually on meth+91.
    Raced a new camero s. s on this run too.
    are the injectors trying to max out because the pump is maxing out or are the injectors just done at low boost?
    i'm sorta skeptical that the injectors are maxed out already but idk. Thanks for the advice.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    If all you have is a Walbro 255 on stock wiring, it might support 400 rwhp on E85 but even that could be risky depending on voltage and fuel pressure and the particular model 255. The 80 lb injectors on E85 can support more like 600 rwhp. My guess is the pump is insufficient.
    Aug 2012
    CT
    Twin turbo LS E36 M3
    Logging fuel pressure would help determine this quickly, but its the pump. 80% DC on those injectors are fine.
    328i Sedan Twin s366's, 6.0LS, TH400, MS3 Ultimate
    9.20 at 150 on 22psi
    Apr 2006
    Minnesota eh?
    86 325es
    You need two of those pumps to max out the injectors
    Jul 2005
    California
    Bima
    pump suggestions?
    Toronto, Canada
    E36 Turbo
    F90000274 or the new F90000285 will do what you need... with a rewire of course as they are very power hungry (high AMP draw).
    Jul 2005
    California
    Bima
    ^ will the walbro 450 f90000267 be ok?
    i'm still looking and allot of the $90 pumps have me worried about knock offs. :/
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    You should be fine with a 267 at your ~17 psi of boost and a 4 bar regulator, but you really won't have any headroom to safely increase boost from there. You want to stay below 80 psi on the 267, because the relief valve starts opening there, and you really don't want to push it to where it could start fluttering. Even at 17 psi and a 4 bar regulator you're getting a bit dangerous playing it so close to the relief valve under boost.
    I would recommend going to the 274 at a minimum on a new pump install. It'll give you headroom to bump up the pressure a tad if you start to max out your injector DC. The 285 is nice, with a ~10% bump in flow, but the amperage goes up even more, and they're kinda pricey right now unless you really need that extra flow.
    Frederick, MD
    '87 e30, '02 e39 Dinan
    Correct me if im wrong, but if you were running out of fuel you would be at 100% duty cycle. Did you add fuel to your map once you changed to e85?
    Id expect if you were running out of pump. the injectors would be pegged to 100% and yet your afr continues to climb. Surprised it didnt pop at that afr.
    Capital Driving Club Car # 102
    How to turbo your car:
    Step one. Install ecu and learn to tune and or have it tuned.
    Step two. Install injectors and retune.
    Step three. Install turbo parts and bits. get it running with out leaks. DO NOT DRIVE IT. Idling should be ok
    Step four. Retune car
    Step five enjoy
    Aug 2009
    Charleston, SC
    x5m
    Quote Originally Posted by euro2fast4u View Post
    Pretty sure that the injectors aren't going to max out if the pump is maxed. Thinking out loud here, but the injectors are set to open for xxx pulsewidth, or duty cycle, at a given load in anticipation of a given fuel pressure. If that pressure is lower than what is anticipated (i.e. the pump is maxed our or failing), they will still open the same amount, but there will be less fuel flowing through. The opposite would be true in the case of a failing FPR. In this case, since duty cycle is calculated independently of pressure, the AFRs climb slowly as a result of falling fuel pressure.
    OP - you deff need more pump. Be sure to check what the e85 flow ratings for pumps.
    e70 x5m vrsf downpipes and turbolabs turbos - current
    e34 540 turbo take 2 - sold
    e34 540 turbo - crashed and burned
    Jul 2005
    California
    Bima
    na, i can change DC to 100% by upping the VE table but it didn't want to go past 13afr
    from an avg VE of 140 to 200. it's done.
    What do you wizards think of this?
    Surge tank with an in-tank wally450e85
    i was told by an e30 racer that the 8mm lines wont' support allot of power
    need 12mm lines.
    so this seems ideal perhaps.
    $559.95
    http://www.radiumauto.com/FST-Fuel-S...dard-P515.aspx
    Oct 2008
    Albuquerque
    a m3 on a 7675
    Check the micro filters in the injectors
    Most likely your issue.
    World record holder for a m52 stock bottom end.
    9.41@153 c4 auto 28" et streets, e34 3.64 gearset 900+hp
    E36 chassis irs world record holder 8.49@162
    Th400, e85, 7685, m50 intake 26.6 lbs of boost
    Jul 2005
    California
    Bima
    That's a very strange suggestion but i'll look into it.
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by Robocop View Post
    Easy way to avoid knock offs is to buy from a reputable reseller... I wouldn't bother with the 267 as the 274 is the same price ($99 USD).. for instance @ racetronix.biz
    Jul 2005
    California
    Bima
    ^ ya i bought it off of real st on ebay they charged more but at least
    i know it's legit. Will save it for the near future using a surge tank.
    So the problem seems to be fixed. Wired the pump to the batt w/ 14g.
    Rewired gss341 by jet jones, on Flickr
    it's using a MBC so boost is shit but, AFR seems great now, it still goes to 80% DC about 15-16psi at higher rpms so based on you guys saying the injectors can handle more power. i'll assume pump is still struggling, but at least it's at a safe afr.
    Check out the tiny stock wires
    Stock pump wires by jet jones, on Flickr
    Pump wire upgrayedd by jet jones, on Flickr
    Jul 2010
    South Florida
    86 ETA Sport 2.7i
    HAHA! Glad you found it.
    Don't visit here much. :/
    Wide Open Throttle Technologies, FL
    -John
    Instagram
  1. Maximum PSI Fuel pump and Injectors!
    By Nj85'325 in forum Forced Induction
    Last Post: 12-06-2010, 12:18 PM
  2. FS s52 air pump / air injector MINT!
    By s52e368 in forum Engines, Performance Parts & Software
    Last Post: 01-09-2008, 11:14 AM
  3. Stock fuel pump + 55# injectors?
    By Ichbinsobose in forum Forced Induction
    Last Post: 12-08-2007, 11:23 PM
  4. Stock Fuel Pump and Injector Size Question
    By niks325i in forum Forced Induction
    Last Post: 11-14-2007, 10:46 PM
  5. 81 320i Fuel Problems. Pump, Relay, Injectors? HELP!
    By uncletammy in forum 1975 - 1983 (E21)
    Last Post: 05-27-2005, 07:34 PM
