I have a wild hair, I think its time to let this car go. I purchased it right at a year ago, drove to Valdosta Georgia to buy it. It has been a childhood dream to have a turbo e36, after owning 4 e36's before this one. It quenched my thirst, but I believe its time to find a new home. I had a bumpy start to ownership, fuel pump died on the way back from Valdosta. Car would not set readiness and could not get a tag for it for months. I was just driving it on the weekends with a dealer plate from work. Bret at Technica has been a stand up great guy helping me get it sorted. After the fuel pump was sorted, he put a muffler on the waste gate that was open dump and tuned it. The drive ability is amazing, since the tune it has not had an hiccup but still will not set readiness. Please do not ask if it will set, we have spent countless months tweaking the tune. No CEL, and fuel trims are spot on. I have put roughly 1,000 miles on it in the last year, mainly to C&O and car meets. What I have/had installed since buying; Fuel pump, plugs, filters, tires, battery, belts, tensioners, new headlights(bosch projectors) and a starter. The only negatives are door panels are pulling away from the pockets, glove box broken/hanging, the car has been hit 10+ years ago due to drivers DOT door and drivers Quarter panel. The PO tagged the passenger fender minor and found another arctic silver fender but the turn signal does not match. I also have a Ben Simpson half cage that I would sell that I never got around to installing due to the interior is just to nice to start cutting up. Price is 16k.
Engine:
Stock S52 3.2L block with 94.5K miles
New OEM S52 cylinder head ($1800)
New OEM rod bearings
New OEM rod cap bolts
Oil pan with 10AN fitting for turbo drain installed
New BMW oil pan gasket
New BMW rear main seal and carrier
Resurfaced block deck to a mirror finish
CES Motorsports cut-ring head gasket plus .070 copper spacer combo (good for 30psi of boost)
ARP 2000 head studs
New BMW intermediate timing chain guide
New BMW camshaft tensioner and guide
Schrick Performance camshafts
New vanos unit Dr. Vanos stage 1
New BMW valve cover gasket and grommets
NGK plugs
M50 manifold conversion with all new BMW gaskets
AKG polly motor mounts
Steward Performance water pump
New Factory BMW thermostat and aluminum housing
New BMW upper and lower radiator hoses
New Behr S54 3 core radiator
New BMW cooling clutch fan (not cheap imitation ones that explode under boost)
New OEM coils
Provent 200 catch can with vacuum pump
New 140 amp alternator upgrade
New engine drive belts
Turbo kit:
TRM stage II kit: (cost $6,800 alone)
Garrett GT35R ball bearing turbo charger
SPA T4 bottom mount manifold (ports cleaned up with grinder)
Tail 38mm waste gate
Stainless steel braided oil feed line with restrictor
Silicone water feed and return lines
Push-lock oil drain hose and fittings to 10AN oil pan
TRM motor mount arm
Powder coated turbo inlet and K&N filter
Powder coated charge pipes 2.5" out to 3" (this system routes above the subframe to keep maximum ground clearance and retains A/C)
600+ hp rated intercooler and frame bracket
Synapse BOV
60LBS injectors
Rally Road 340LPH drop in fuel pump
3" downpipe to 3" Pypes resonator out to 3" Magnaflow muffler
Factory tuned DME for excellent drivability
NXS manual boost controller.
DEI heat sleeves and heat wrap on all hot side piping
Custom manifold heat shield
Transmission:
BMW ZF 5-Speed:?
Remanufactured Transmission from ZF
Clutch Masters Twin Disc Ceramic Clutch (best clutch available good for +1,000 HP $1,500)
Rally road pivot pin
New BMW clutch fork
New slave cylinder
Red Line fluid change
New Guibo
Dinan short shifter
New BMW tranny mounts
Suspension:
OE sport springs
Koni single adjustable front and rear shocks struts
OEM front X-brace
UUC sway bars
New HD front sway bay end links
New OEM HD rear sway bar end links
ECS SS brake lines
New OEM "swapped" strut mounts (-2.80 deg camber)
New front and rear spring pads
New front controll arms
New AKG FCAB bushings
New front inner and outer tierods with new rack boots
Professional alignment
Rear SPC camber arms
New HD OEM rear shock mounts and reinforcements
Cool Carbon race/steet brake pads
AKG rear subframe mounts and diff mounts
MM underpanel
Strut tower brace
Motor mount reinforcement plates
Sway bar reinforcement plates professionally welded
R-tab reinforcement plates professionally welded
New 17" x 8.5" Et 40 Apex Arc-8 Wheels
Interior/exterior:
New door handle trim pieces
New Rear vent window gaskets
New Rear window trim
New cowl vent plastic
Euro clear tail light and side marker conversion
Various other trim pieces
Euro Mtech M3 steering wheel
Rally Road dual gauge pod mounts
AEM failsafe boost/AFR
Visit the PO's for sale add when I bought it
https://www.bimmerforums.com/forum/s...ight=TURBO+E36
It would really help if you have some engine bay pics
If you have seen the jalopnik "nice price or crack pipe" poll on for sale posts.... I would vote this as nice price.
Having A SC e36 I can say this is a great deal, if the car is dialed. I didn't read the whole post, if its running good hell yeah I would buy this for around asking. Sweet ride.
