My setup: m52 (.140 mls and arp's) on 91 pump and meth injection on a 6266
Was doing some datalogging today on my "higher boost" setting around 17 psi and saw that timing was being pulled anywhere from 2-4 degree's throughout the rev range once in boost. Is this considered unsafe since some knock was being detected causing the timing to be pulled? Or is it just the knock sensors doing their job and pulling enough timing to keep the engine safe?
96 328is turbo. Built 3.2, 6266, RSI Manifold
Contact your tuner..
1989 535i - sold
1999 M3 Tiag/Dove - sold
Tuner doesn't think it should be knocking either at the boost level i'm at with meth. I would say its still a pretty conservative tune with peak timing around 16.5* and high 10's on the afr gauge. I am wondering if my knock sensors are picking up a different sound in the engine bay or if they are simply going bad. I'm going to see if it still pulls timing on wastegate pressure of 10 psi and if it does that will tell me that the knock sensors aren't functioning properly.
If the shells are intact, the knock sensors are not picking up another sound.
There are a lot of reasons the car pulls timing. Your tuner should be able to look at the log and decide if it’s knock or not. Log the following: tps, load, current-knock, rpm, boost and afr.
[edit: Added punctuation]
1989 535i - sold
There is no "one size fits all" tune. As recommended... take a log and send to your tuner and have him adjust accordingly. There is no such thing as working the other way around (you trying to curb knock by other means). It can very well be that your setup has a lower knock floor than other setups. It's not uncommon.
1989 535i - sold
Makes sense. it was pulling around 4 degree's of timing at some points when it was hitting around 16*. That would mean it was sensing knock up until like 12*. (16* "stock tuned" setting and then pulling 4 degrees on top of that) 12* at 17 psi with meth injection seems like it would be well below the knock threshold, but I can understand what you are saying how every setup is different. I'll be talking with my tuner as well.
IAT and humidity are a huge contributor to knock tendency as well.
Try a bigger meth nozzle perhaps.
It could be the distribution of meth to each cylinder is not equal.
