Results 1 to 13 of 13
Thread: Knock sensors causing timing to be pulled DANGEROUS?
    Oct 2015
    San Rafael, California
    1996 bmw 328is turbo
    My setup: m52 (.140 mls and arp's) on 91 pump and meth injection on a 6266
    Was doing some datalogging today on my "higher boost" setting around 17 psi and saw that timing was being pulled anywhere from 2-4 degree's throughout the rev range once in boost. Is this considered unsafe since some knock was being detected causing the timing to be pulled? Or is it just the knock sensors doing their job and pulling enough timing to keep the engine safe?
    96 328is turbo. Built 3.2, 6266, RSI Manifold
    Mar 2012
    Renton, Wa
    98 m3
    Contact your tuner..
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Toronto, Canada
    E36 Turbo
    Quote Originally Posted by Willmartens View Post
    "Ideally" you would want 0 timing pull at all times.. so yes the ECU is doing it's job and keeping your engine safe. You should probably turn the boost down slightly or get a revision from your tuner though.
    Oct 2015
    Tuner doesn't think it should be knocking either at the boost level i'm at with meth. I would say its still a pretty conservative tune with peak timing around 16.5* and high 10's on the afr gauge. I am wondering if my knock sensors are picking up a different sound in the engine bay or if they are simply going bad. I'm going to see if it still pulls timing on wastegate pressure of 10 psi and if it does that will tell me that the knock sensors aren't functioning properly.
    Mar 2012
    Renton, Wa
    98 m3
    If the shells are intact, the knock sensors are not picking up another sound.
    There are a lot of reasons the car pulls timing. Your tuner should be able to look at the log and decide if it’s knock or not. Log the following: tps, load, current-knock, rpm, boost and afr.
    [edit: Added punctuation]
    1989 535i - sold
    Toronto, Canada
    E36 Turbo
    There is no "one size fits all" tune. As recommended... take a log and send to your tuner and have him adjust accordingly. There is no such thing as working the other way around (you trying to curb knock by other means). It can very well be that your setup has a lower knock floor than other setups. It's not uncommon.
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by NOTORIOUS VR View Post
    Exactly
    1989 535i - sold
    Oct 2015
    Makes sense. it was pulling around 4 degree's of timing at some points when it was hitting around 16*. That would mean it was sensing knock up until like 12*. (16* "stock tuned" setting and then pulling 4 degrees on top of that) 12* at 17 psi with meth injection seems like it would be well below the knock threshold, but I can understand what you are saying how every setup is different. I'll be talking with my tuner as well.
    Jun 2004
    The D, MI
    97 M3, 98 328i, 13 Cruze
    IAT and humidity are a huge contributor to knock tendency as well.
    Oct 2015
    Quote Originally Posted by Kevin325i View Post
    IAT's pretty much never exceed 100 degrees with meth and its only around 70 degrees outside where I live
    Jul 2005
    California
    Bima
    Try a bigger meth nozzle perhaps.
    Vancouver, B.C., Canada
    '97 M3
    It could be the distribution of meth to each cylinder is not equal.
    Toronto, Canada
    E36 Turbo
    Most certainly it isn't (and often overlooked issue).
  1. Can a bad O2 and or Knock sensor cause a no start?
    By doclees in forum 1991 - 1999 (E36)
    Last Post: 06-04-2017, 06:02 AM
  2. knock sensors causing misfire?
    By bandittwo2 in forum 1995 - 2001 (E38)
    Last Post: 11-05-2009, 02:58 PM
  3. Knock sensor caused by this????
    By calburke in forum 1992 - 1999 M3 (E36)
    Last Post: 06-20-2009, 07:00 PM
  4. Replies: 15
    Last Post: 05-28-2006, 03:11 PM
  5. Bad Knock Sensor pull timing and not set off cel
    By tonym in forum Forced Induction
    Last Post: 05-05-2006, 03:44 PM
