Results 1 to 2 of 2
Thread: Getting some vanos/timing fault codes on my 650i
    May 2018
    Arad
    '08 bmw 650i
    Hi there fellas. I recently did a head gaskets,valve stem seals replacement on my '08 650i e64 with 160k km and now I get the check engine light and some vanos/timing related fault codes, car also seems to run lil rough on low rpm's.There is also a strange noise comming from the left top of the engine(see video link). What could I try before re-opening the valve covers, maybe vanos position relearn, or RAM back up or what else? Open to any advice, thanks
    https://streamable.com/1lsgd
    May 2018
    Arad
    '08 bmw 650i
    I did the RAM BACKUP and now is only one vanos related fault code left, 2A8C but still idle is not stable and check engine light is on. The strange noise from engine is still there too.
  1. New vanos solenoids - fault code came back?
    By Taymar in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 08-16-2017, 09:37 PM
  2. Single VANOS and Fault Codes
    By Jacoreman in forum 1996 - 2003 (E39)
    Last Post: 03-12-2013, 02:58 PM
  3. VANOS Fault code
    By mctai2 in forum 1999 - 2006 (E46)
    Last Post: 10-18-2004, 12:51 PM
  4. "Time to Closed Loop Temperature Too Long" Fault Code
    By WK446 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-20-2003, 03:37 AM
  5. E6 Fault code: PreCat Oxy Sensor response time?
    By Kam in forum 1991 - 1999 (E36)
    Last Post: 08-08-2003, 09:40 AM
