Results 1 to 17 of 17
Thread: BM53 Aux option not working, Help!
    Jul 2006
    GA, NY
    2001 530i 5spd/2001 M5
    I recently upgraded my BM53 with one that supports AUX and Satellite radio. My car is a 2002 525iT and does not have DSP or the 6 disk CD changer.
    Since I have factory navigation and my car has a 11/01 build date, I had to run the oem aux cable to the C connector on the radio in the back of the car.
    I have the correct pin connectors plugged into ports 3, 4, and 10.
    However, when I click mode on my Nav, AUX does not pop up. Need HELP!
    I’ve tried:
    Resetting the radio through the Nav
    Swapping between MK3/ MK4 Nav
    Unplugging battery
    Checking connectors
    Andy
    USA
    2003 530iA Sport
    If I understand you correctly you have purchased an OEM AUX cable that contains the required resistor but the AUX option still does not appear?
    If you have the correct cable and it is correctly plugged in, the system will automatically detect and display.
    2003 530iA Sport - Titangrau Metallic/Schwarz Montana
    Build Codes: ZSP/ZPP/ZCW. Born on date: 09/02, Dingolfing, Deutschland
    |NAV MKIV WAZE | PP | CWP | Xenons | Style 42s | Rear Shades | OEM ULF Bluetooth | Euro Armrest | Beisan Vanos Seals | OEM Aux Input |
    Los Angeles, CA
    Formerly 03' 540i
    Post your BM53 part number.
    2003 BMW 540i [Sterling Gray / Gray]
    [Msport] [Mods from A-Z] [Two-Tone Interior]
    Stuff For Sale :
    All types of E39 OEM Used HVAC Buttons
    Other E39 Parts, see my ebay! [Click]
    Oct 2017
    VA
    1998 328i, 1990 Spec E30
    If you still have your old BM53, I am in need of one.
    Jul 2006
    GA, NY
    Quote Originally Posted by Dking078 View Post
    65126976961
    Lawrenceville, GA
    4 BMWs.
    Quote Originally Posted by carlova789 View Post
    65126976961
    That is a capable unit. Is the Aux kit you bought genuine BMW or one of the aftermarket ones? I have heard some of them don't work properly.
    2001 Z3 3.0i -Oxford Green/Sandbeige
    2016 428xi -Estoril Blue II/Black
    2018 430iC- Estoril Blue II/Black
    2018 330it - Melbourne Red/Venetian Beige/Black
    Los Angeles, CA
    Formerly 03' 540i
    Second thing is did you buy the proper Nav spec aux cord or the Non-nav spec? The connector is the same, but the pinouts are different.
    Stuff For Sale :
    Jul 2006
    GA, NY
    Quote Originally Posted by amancuso View Post
    Straight from the dealership
    I bought the one with the 3 pins. I installed it the same way e39 source did theirs.
    https://www.ecstuning.com/b-genuine-...t/82110149390/
    It came Without the black connector which is not needed.
    Los Angeles, CA
    Formerly 03' 540i
    Hmm. If it came without the black connector, how are you connecting it to the BM53?
    That black connector is needed and since you used a Non-Nav spec Aux cord, you MUST repin the connector as per #14 in their DIY.
    I've had both plugs in my hand at one point, pins are arranged differently.
    Stuff For Sale :
    Jul 2006
    GA, NY
    Once I get back to my laptop, I’ll post the screenshot.
    I have them plugged into the C connector to pins 3,4,10. Ryan takes his connector apart to do so.
    Lawrenceville, GA
    4 BMWs.
    Not sure if this will be helpful or not...
    "Okay... Here's what I'm being lead to believe. The software version doesn't quite matter. What matters is the manufacturing date.
    There's a bit on the sticker where it says "MANUFACTURED:" and then gives a date, month, and then a "1W" or "AP."
    It appears as though none of the units with "AP" marked on them were a software version 42, so they appear to be from newer vehicles (at least from what I've found.) Also, units with software version 40 come on "1W" units, but don't appear to have AUX input capabilities.
    Simply put, you need a unit with "AP" on it and not "1W." Software version doesn't matter.
    I can back this up, too. The original post has a "AP" unit going in, and it worked.
    This video from E39Source also shows him replacing a software version 50 "1W" unit with a SV 40 "AP" unit. https://www.youtube.com/watch?v=P_GL-gqBUXM "
    Jul 2006
    GA, NY
    Good information, I’ll check my PN again! As far as I know it came out of an 06 M3.
    Jul 2006
    GA, NY
    So I'm looking at this unit. I don't see AP or 1W: https://www.ebay.com/i/132650703672?chn=ps
    Jul 2006
    GA, NY
    Tried installing another BM53 that has the aux function. Still not working
    Jul 2006
    GA, NY
    Updated the MK4 to V32. NO BUENO. My next step would be to add a CD changer.
    CT
    E28, E32, E39, E53, E90
    I made a DIY guide video for the factory BMW aux kit, there are quite a few comments about people with aftermarket aux kits (knock off of the OEM version?) not being able to get it working. I think OEM is the key, it's only $34 currently.
    Link: https://youtu.be/2nyaynmK0AA
    Jul 2006
    GA, NY
    Quote Originally Posted by rbelton View Post
    I did the exact same thing you did except my radio is in the trunk. I bought the cable straight from the dealership.
    I'm going to exchange it for another tomorrow to see if the cable was defective. It actually came without the black housing and the instructions had some coffee stains on it lol.
  1. Aux Fan not working need help
    By E39 Wagon in forum 1996 - 2003 (E39)
    Last Post: 09-28-2012, 12:36 AM
  2. Option Buttons Not Working! Help!
    By hotimportknight in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-19-2006, 09:06 PM
  3. Cigarette lighter not working...help
    By KraZy007 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-25-2005, 10:51 PM
  4. aux fan not working. please help, its hot!
    By sage in forum 1991 - 1999 (E36)
    Last Post: 07-03-2003, 11:52 AM
  5. Ac Not Working Help!
    By Silver740i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-21-2002, 04:14 PM
