Results 1 to 4 of 4
Thread: X3 X drive Traction control fail
    Feb 2016
    North lakes
    Bmw x3 2.5l
    I've been experiencing juddering in the transmission line whilst turning to park for a while.. usually slowly.
    The gearbox is obviously changing down and at every gear change the car would judder.
    At first we thought it was a failed yoke in the drive shaft to the rear diff based on the sloppy start off juddering feeling.
    I changed the front prop and it was worn out.
    Fast forward to today and we're getting drive line traction control failure... mostly when driving from a stop position... even without turning.
    Warning lights are the 4x4 in a circle..
    ABS and hand brake on light.
    I put the vehicle on grass. Stopped. Turned off and on.. then pulled forward quickly and the left rear wheel spun like crazy...
    It should have been braked and power sent to the other wheels.
    We assessed the tyre and at 9 months old .. all tyres are wearing evenly but the rear left has terrible wear on the outer edge.
    Might this be a wheel position sensor fault?
    Turning it feels like a 4x4 in diff lock on tarmac.. you can hear and feel tyres scrubbing in that scenario.
    I'll get it plugged in but am concerned about dramatic costs.
    I did the evaporator dash out job .. rocker gasket.. coils and all oil breather.. separator and vacuum hose replacements myself but driveline is trickier for me without a ramp.
    Vehicle is June 2004 x3. 2.5L
    Many thanks
    Feb 2009
    KC North, MO, USA
    1996 740iL
    Towed to X3 forum.
    Jan 2016
    Ca
    2001 525it
    I would check the transfer case motor plastic gear first
    Feb 2016
    North lakes
    Bmw x3 2.5l
    Thanks . Is this easy to access ?/ assess ? Or us this a 4 post lift mechanic job?
  1. Transmission fail safe /ABS/ traction control
    By tribalone in forum 1995 - 2001 (E38)
    Last Post: 03-22-2012, 11:54 PM
  2. Replies: 0
    Last Post: 12-15-2009, 02:48 AM
  3. '99 540i Service Engine/Trans Fail/Traction Control Lights
    By 540inewbie99 in forum 1996 - 2003 (E39)
    Last Post: 01-07-2008, 04:59 PM
  4. FAO Kevlar ~ Why Did Race Logic Traction Control Fail?
    By Hyperion in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-02-2002, 10:56 AM
  5. ever drive with the traction control off?
    By sage in forum 1991 - 1999 (E36)
    Last Post: 07-01-2001, 09:22 PM
