Results 1 to 9 of 9
Thread: Help ! 2008 535xi turbo failure burning excessive oil
    Oct 2016
    Bloomfield hills, mi
    08 bmw535xi
    Hello All,
    your insight is is truly valuable . I currently have an 08 535xi. I was notified by my local dealer a year ago that my turbo was failing however they stated I would be fine driving it. About 3 weeks ago my vehicle starting making whistling noise while accelerating so I took my car to the local dealer whom informed me that the turbos have completely failed . I have been adding an excessive amount of oil about 1 quart per week at about 300-400 miles . I added oil on Tuesday and literally the light just came back on. Is this normal when turbos fail ??
    before I would add at about 1200 miles . My car has about 165k miles on it.
    your help is appreciated also I've found someone to replace the turbos for $900 with a 6 month warranty. wondering if I should
    Check to see if there is a bigger problem before spending extra money.
    Mar 2008
    Coquitlam, BC, Canada
    2003 530i
    You are aware, $900 is likely just the labor to replace the turbos?
    Sent from my LG-H915 using Tapatalk
    Jul 2010
    Leland, NC
    85 €735i 08 550i/6
    Ask whoever said that what the total parts and labor cost will be.
    Sent from my LGLS755 using Tapatalk
    Mar 2001
    Amesbury, Massachusetts
    BMWs and Mini's
    I expect the person is quoting you labor only.
    -James
    Turner Motorsport
    / // Parts and Performance for BMWs
    16 South Hunt Road
    Amesbury, MA 01913
    800-280-6966
    info@turnermotorsport.com
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    $900 might also be the parts cost for a pair of rebuilt turbos. Add $900 labor.
    Oct 2016
    08 bmw535xi
    He said its parts and labor .its a used part which is why he offered 6 months. The parts won't arrive until tomorrow or Thursday.
    Oct 2016
    08 bmw535xi
    Is it normal to burn excessive oil with a failed turbo ?
    DE, USA
    '15 435i,'10 535i,'08 X5
    Normal isn't the word I would use, but there is a turbo failure mode that does cause oil consumption.
    Jun 2005
    New England
    $900 is fair for two used turbos installed but I would probably not risk the used turbos since I would not want to pay for another set or do the labor again. N54 is common from 07-10 are very limited after that (some “is” models), so used ones are likely old though some were replaced under warranty along the way.
  1. HELP 2008 535xi vacum noise battery drain
    By Louieejoee in forum 2004-2010 (E60,E61)
    Last Post: 02-11-2018, 09:04 PM
  2. 2005 325xi burning excessive oil
    By KB99 in forum 1999 - 2006 (E46)
    Last Post: 07-31-2015, 09:59 AM
  3. 2008 535xi turbo replacement costs??
    By Oregon in forum 2004-2010 (E60,E61)
    Last Post: 07-12-2015, 01:23 PM
  4. Intermittent Coolant Leak Help 2008 535xi
    By ghoresta in forum 2004-2010 (E60,E61)
    Last Post: 04-28-2015, 10:59 PM
  5. 01 325Ci burning excessive oil - recall?
    By Dalton in forum 1999 - 2006 (E46)
    Last Post: 09-17-2003, 02:02 PM
