When pressing the gas pedal in neutral, only goes to about 4000 rpm. why does the car have low power??
car is a 1998 z3 with the 4 cyl. engine
Wrong section...
It obviously has low power because no turbo has been installed. To fix it, remove the engine, install an S52 with a 6766 turbo or similar. This should sort out that pesky low power issue you have.
