Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
Thread: 1999 or 2000 which to buy?!
  1. #26
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Have you checked the coolant level. Does the temp control knob feel move easily. Any resistance. These cars can be a little tricky to fully bleed the coolant system according to some here but the best advice has been to remove the top hose from the rad and fill from there. Also the thermostat may be stuck open. Generally the temp gauge will be at 12:00 when at operating temp if it's consistently below or dips down when accelerating that's likely what's causing it
  2. #27
    Jun 2018
    South Carolina
    Z3
    Haven’t tried that I will thanks for the tip!
  3. #28
    Jun 2018
    South Carolina
    Z3
    The control knob seems to move pretty easily is that a good or bad thing?
  4. #29
    Jun 2018
    South Carolina
    Z3
    I replied on Tapatalk but don’t see it on here yet does it have to be approved first? And the control knob seems to move fairly easily
  5. #30
    Mar 2004
    San Diego
    2000 Z3 2.3, 2014 M235i
    Quote Originally Posted by Winyah View Post
    What is a common point of failure is the knob snaps in the rear for the temp control (mine has this problem also) It basically is stuck on cold, or cannot open the door fully for hot, For me sometimes if I move the knob all the way to hot, and turn it on full blast, I think pressure alone will move the door. And same goes for switching it back to cold. But you only get two settings... full hot or full cold lol.
    Suspension: Bilstein Sports, GC Coilover conversion, IE Subframe Bushings, IE RTABs, M roadster sways, M roadster front control arms, M roadster Front calipers/hubs.
    Engine/Driveline: M54B30 intake Manifold, Dinan CAI, ZHP Cams, Headers, Underdrive pulleys, Conforti Software, 3.46 diff.
  6. #31
    Kent, Ohio
    1998 M Roadster
    No heat could have any number of causes, but a very common cause is a dangerously low coolant level--it would be wise to check (when it's cold).
  7. #32
    Jun 2018
    South Carolina
    Z3
    If I check the coolant do you have bleed and vent afterwards feel like I’ve read that is a nightmare
  8. #33
    Jun 2018
    South Carolina
    Z3
  9. #34
    Kent, Ohio
    1998 M Roadster
    No, you just check the level. If the coolant level is so low that it is not even high enough to fill the heater core, then you will have to refill it, and may indeed have bleeding issues, which can be somewhat troublesome, but not the nightmare of overheating due to to low coolant level--remember that blown head gasket we were talking about...
  1. Replies: 3
    Last Post: 05-07-2009, 06:48 PM
  2. Wanted: Grey or Silver 1999 or 2000 323i or 328i 4dr
    By littlepaul in forum BMW Cars For Sale / Wanted
    Last Post: 11-29-2006, 10:33 PM
  3. Looking at a 2000 540, good buy?
    By EdZorX in forum 1996 - 2003 (E39)
    Last Post: 10-20-2006, 10:23 AM
  4. Differences between 1999 and 2000 3 series
    By AnthraxCrumpet in forum 1999 - 2006 (E46)
    Last Post: 08-09-2005, 09:25 PM
  5. 1999 vs 2000 540, engine changes etc.
    By E46/330/CP in forum 1988 - 1996 (E34)
    Last Post: 04-25-2004, 07:22 AM
