Results 1 to 2 of 2
Thread: Boost leak or wastegates?
    Oct 2014
    North West Georgia
    92 318i
    The question is pretty simple.
    Is there any proper way to confirm wastegate issues without actually removing the turbos and checking them? Or is it a matter of ruling out boostleak, boost solenoids, vac' lines and such then "assuming" it has to be wastegate since there are no other options?
    I'm having issues with a Tune/Exhaust 07 335i, only making 10lbs in 4th gear WOT, target being 14.5.
    Boost solenoids have been swapped, vac lines replaced, checked for a boost leak and didn't find anything. Any other options?
    Oct 2014
    North West Georgia
    92 318i
    To answer my own question, I ended up pressurizing the system again after making this post. I found small leaks on the block-off bolts for the Meth ports on my aftermarket charge pipe. Thread tape fixed that, but I still wasn't hitting peak boost. Ended up adjusting the wastegate actuator rod on the rear wastegate, zero boost issues now. It drives like a completely different car.
  1. !@#$@! Boost Leak :(
    By rootuddha in forum Forced Induction
    Last Post: 03-13-2007, 02:44 PM
  2. major boost leak lead to oil leak?[somewhere]
    By Jean-Claude in forum Forced Induction
    Last Post: 04-17-2006, 01:06 AM
  3. Solving boost leak on the 3.2 motor
    By RRdawho? in forum Forced Induction
    Last Post: 04-12-2006, 08:13 AM
  4. New dyno #'s w/new race chip & boost leak fixed
    By m3boost in forum Forced Induction
    Last Post: 06-27-2005, 09:50 AM
  5. Dynoed my E30 turbo! Boost leak( PICS)
    By diegom6 in forum Forced Induction
    Last Post: 05-26-2004, 11:00 PM
