Results 1 to 16 of 16
Thread: Need help with DME fast!!!
    Jun 2018
    Lithuania
    1996 bmw e38 740
    Hello guys, this is my first post on bimmerforums, and im looking for a quick answer who really knows their stuff. Im about to order a DME for my e38 740i m60b40, but it was from a 4.0 e32 and im not sure if it will fit and everything will work as it should. Since the cars use the same engine, will it fit the e38 m60b40? The code of the part is 0261200404 1703400 (heres the link if that helps) https://srotas24.lt/automobiliu-daly...233430882.html THANKS!!
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Based on the part database...the BMW part number for the DME you posted (12 14 1 703 400) is retrospectively exchangeable with several DME's that were used on the models below (or click link): http://www.realoem.com/bmw/enUS/partxref?q=12141427366
    Take note of specific build date ranges...does your e38 fall within the build date listed?
    • E34 w/build dates of 3/92-6/96
    • E32 w/build dates of 3/91-4/94
    • E38 w/build dates of 7/93-3/96
    • E31 w/build dates of 12/92-2/96
    Jun 2018
    Lithuania
    1996 bmw e38 740
    My 1996 08 3.5 has been swapped to a 94' 4.0, but i guess it should fit since the engine is 94' right?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Your 1996 735i had an M62 engine - you have swapped in an M60 engine - and that isn't going to work as the control of the gearbox and communications to the IKE are different. Only one person has ever done this (M60 engine into an M62 chassis) - and it was a HUGE commitment - not to be recommended. It would be better to find an M62B44
    My BMW Repair YouTube Channel
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    Unless the older models are different it will need to be virginized to work with your EWS and keys. I don't think you can just drop it in and go.
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
    Jun 2018
    Lithuania
    1996 bmw e38 740
    Thanks for the answers guys, no choice but to try it now since the m60 is already in the car and only missing the DME.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    It's not going to fit - different shape, different connector
    Sent from my SM-G935F using Tapatalk
    Jun 2018
    Lithuania
    1996 bmw e38 740
    Could you please send me an example or a part code of how its supposed to look to fit?
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Let's not be pessimistic, Timm! It only took 3 years, a few lawsuits and approx 5 mechanics for the other guy to make this happen . And his car is probably not even road legal.
    But other than that... it's a piece of cake!
    (northeast) Indiana
    Quote Originally Posted by tatscru1 View Post
    Why in the heck wasn't this bit of information in the FIRST post....ahead of the "my e38 740 m60b40"? Because that is not what you really have...you have a 735I with an Aug/96 build date that you've plucked a (not working yet) M60b40 engine into.
    As mentioned above...the DME is not the only thing to consider...you have EWS, LCM, and ZKE coding a the least to consider. Misrepresentation of what you actually have and are starting with as a base leads to incorrect replies and info. The 8/96 build date puts you in EWS II territory...which means contending with a transmitter-receiver, EWS control module, and DME that are all coded with a specific ISN (individual serial nbr) that must match the other components as well as the key before the car will start.
    Jun 2018
    Lithuania
    1996 bmw e38 740
    Sorry if i mislead you guys, i am not a mechanic myself and not the one doing the swap, my mechanic just told to me to start with a new m60 DME, since even he doesnt know 100% how to get this thing working properly.
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    There was a guy here from PA who made this happen, you need to contact him. Took him years though. Sorry, cant recall his name but you might be able find it by advance search.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Although some one has done it, it would have been easier to chew an M62 block from a lump of aluminium. Really, it is much simpler to get the right engine in there!
    Jun 2018
    Lithuania
    1996 bmw e38 740
    Bought this engine with my last pennies, so another engine is not an option, at least for now sadly. Mechanic said hes going to try to program the EWS out completely from the m60 dme block, well see how that works out
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by timm View Post
    although some one has done it, it would have been easier to chew an m62 block from a lump of aluminium.
    lol
    I'm sorry Man! This wont work, it would be a huge expense to get this working. You should probably try to sell the engine and the car separately to make some money back.
    Jun 2018
    Lithuania
    1996 bmw e38 740
    Hey guys, ive bought a new DME from a 94' 4.0 e38 without EWS alltogether , and with this DME the car wont even crank. Any ideas on what i should do next? Im determined to get this working
  1. need help wiring DME e46
    By galskap in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-27-2009, 12:20 PM
  2. Need help bad and fast -- no start
    By Philboski in forum 1996 - 2003 (E39)
    Last Post: 11-15-2008, 01:18 PM
  3. 92' owners, need help with DME...
    By mrdezyne in forum 1991 - 1999 (E36)
    Last Post: 01-16-2008, 08:15 PM
  4. Need Help From Experts Fast !
    By databass in forum 1992 - 1999 M3 (E36)
    Last Post: 01-24-2006, 02:52 PM
  5. Need Help Installing Shark Fast!!
    By Zippylock in forum 1992 - 1999 M3 (E36)
    Last Post: 01-20-2006, 09:00 PM
