Results 1 to 8 of 8
Thread: Breaking issue....kind of....
    Jun 2018
    Richmond Va
    2001 BMW 325ci
    Hello all... I have a 2001 325ci convertible that runs great but after driving for about 10 min and everything gets warmed up, the break light on the dash comes on and the vehicle jerks quickly to right. After it drives smoothly again, but break light stays on for duration of car running. new breaks. cant find anything when put on computer at shop. just at a loss... any help anyone?
    Pelican Parts's Avatar
    Pelican Parts is offline Senior Member Supporting Vendor
    Aug 2013
    Harbor City, CA
    '02 E39 Touring
    Sounds like a possible warped brake rotor. Have you gone through the suspension to make sure everything is tight? When reading the codes, are you using a scan tool for BMWs?
    888.280.7799 | 6am - 5pm PST
    Jan 2015
    Timaru, New Zealand
    Two Z3 Roadsters
    Scan for error codes. If the brake light comes on, there will be an error code.
    1999 2.8L Z3 Roadster,
    2000 3.0L Z3 Roadster,
    Chicago, IL
    2001 330i and 2005 330i
    What do you mean by "new brakes"? Did you do the work or someone else? Re-check that everything is cool with that work. Does the RF spin freely when jacked up...
    Johnny Murray
    Nov 2017
    Netherlands
    E46 320i 2001
    Sounds like caliper hangs , heats up.. jams up...
    How the rims feel, the one that hangs way more hot ?
    Dec 2013
    Chicagoland area
    EXOTICS
    You need a scan performed with,
    BMW software or a BMW specific scan tool,
    as you can't communicate with all the BMW modules without.
    May 2010
    Honolulu, Hawaii
    '73 E9, '94 E34, '02 E46
    1. it's "brakes" not how you spelled it.
    2. "Warped rotor" is usually a misdiagnosis, and anyways a warped rotor would reveal itself the first time you used the brakes. Since you don't report this, a warped rotor is not your issue. READ THIS, written by the pros: http://www.stoptech.com/technical-su...nd-other-myths
    3. BMWs used to be notorious for the front brake flex lines swelling internally and not allowing brake fluid to return to the master cylinder. This causes the caliper to stay closed and pads in contact with the rotor, overheating the pads and in turn affecting their coefficient of friction. Diagnose this next time after it happens by putting your hand at first near, then on the front wheel hubs. If on is hot (I suspect the right side from your description of brakes pulling that way) you have a sticking caliper and need new flexible brake hose lines. In my cars they have required 14 mm open end wrench and and an 11 mm flare nut wrench to remove/replace, YMMV. You can use the stainless braided hoses if that's your thing. You'll need to bleed the brakes afterwards.
    4. The brake light monitors the level of fluid in the master cylinder reservoir and the position of the parking brake. Check the fluid level and that the parking brake is fully disengaged. Sometimes the sensing switch on the parking brake mechanism can be bumped out of position, check for that too. The last thing the dashboard light checks is the thickness of the brake pads, so make sure you have adequate thickness remaining. Brake pads come with a slot in them, and if you can't see the slot, it's time for new pads. At the mileage your car has, I'd also check rotor thickness and compare to minimum thickness spec.
    5. I herewith invoke Mechanic's Rule: When something is screwed up, look into the last thing you messed with. You see, far too often we create our own problems through misdiagnosis, ignorance or clumsiness. Most of what I've learned has been discovered by having to do things twice. We are our own worst enemy, more times than most of us, including me, will admit. Thus, if you've messed with the brakes, it's entirely possible that what you did, however well-intentioned, contributed to the problem rather than the solution. AMHIK!
    Charlie
    Your mission, should you decide to accept it, is to add value to these threads, either by pictures or by descriptions, so the next person with the same or similar problem stands on your shoulders.
    Nov 2017
    Netherlands
    E46 320i 2001
    Just replaced.. guess what 4 out of 4 calipers , due the same problem as OP.
    ( actually, rear one's was a freak incident that screwed one of them up )
    They all got there time, last bmw i replaced my calipers at 240k , this one now at 270k
    Full replacement kits are so cheap these days that its nearly not worth it to revision them.
    Computer won't find this mechanical issue ( unless, well.. MAYBE it will show something on the wheel sensors.. MAYBE )
    Just do as mentioned above, temp-check your wheels..
    Hot .. not good.. mild "warm" only acceptable after aggressive driving.
    ( well.. unless track day or something )
  1. Soft Top Issue - Kind of Strange
    By x888jmo in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 08-04-2017, 11:12 AM
  2. BMW 535D Automatic transmission and breaking issue.
    By Roonie535d in forum 2004-2010 (E60,E61)
    Last Post: 09-17-2013, 02:47 PM
  3. E46 Break Issues (Viberates / Caliber sticking)
    By LiyaBMW in forum 1999 - 2006 (E46)
    Last Post: 05-06-2013, 10:45 PM
  4. Breakes issue
    By jcj1 in forum 1999 - 2006 (E46)
    Last Post: 07-12-2011, 03:39 PM
  5. Need some help with a break issue
    By nvantine in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-09-2009, 11:32 PM
