Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 2 of 2
Thread: Tire Pressure Notification
    Feb 2018
    USA
    Lexus ES 300
    I just bought my X3 in March 2018.
    I am getting the following message in my console.
    "You can continue driving. Check tire pressure when the tires are cold and adjust if necessary. Perform a reset after adjustment. See owner's manual for further information."
    Following is the tire pressure I see when the tires are cold.
    Front Left - 34 Front Right - 37 (Recommended for front tires -32)
    Rear Left - 37 Rear Right - 38 (Recommended for rear tires - 35)
    I am not sure if it is normal to get this notification message.
    Please advise how to handle this...
    Jun 2018
    San diego
    Toyoto, ford
    Could be a wiring issue or faulty module. check the vehicle for fault codes. If system is not working properly, a fault code will be set. This will be your best bet when diagnosing.
  1. What is the best Analog Tire Pressure gauge...
    By ///Major Havoc in forum 1992 - 1999 M3 (E36)
    Last Post: 06-19-2001, 03:27 PM
  2. What tire pressures to use for 235/45/17"?
    By BS05ZHP in forum 1992 - 1999 M3 (E36)
    Last Post: 06-03-2001, 01:55 PM
  3. tire pressure?
    By FLiPModE in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-27-2001, 01:51 AM
  4. What tires pressures do you guys run for auto-x?
    By Kevlar in forum 1992 - 1999 M3 (E36)
    Last Post: 03-15-2001, 02:39 PM
  5. 19" tire pressure
    By guysimpson in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 03-07-2001, 11:38 AM
