Bavarian Soundwerks
Results 1 to 3 of 3
Thread: Bmw e46 keyless entry problems
    Jun 2018
    UK
    1998 BMW M3 Coupe
    My son has a 03' 3 series sedan. Both keys have stopped working (keyless entry) and after replacing the battery in one of them it still doesn't work. The central locking still works from the button inside the car. Is it possible to fit an aftermarket keyless entry kit to the existing central locking and just retain the keys to start the car?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The GM5 module controls the keyless lock/unlock system. It’s located above the fus panel in the glove box. Go to www.bmwgm5.com to learn more.
    The system has an antenna in the rear windshield. The signals from the keys are amplified by an amp located in the driver’s side “C” pillar. The “C” pillar is the part of the roof that flows into the body behind the rear seat. That could have stopped working.
    So, before you start throwing parts at the problem do some research.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Have you tried re-initializing your keys after swapping out said battery?
  1. Bmw e46 keyless entry problems
    By han777 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-31-2017, 09:23 AM
  2. BMW Keyless Entry Problems
    By roriii in forum 1992 - 1999 M3 (E36)
    Last Post: 02-10-2008, 08:30 PM
  3. 1998 bmw 328ic keyless entry problem
    By 1998BMWIC in forum 1991 - 1999 (E36)
    Last Post: 03-08-2007, 10:25 PM
  4. Keyless entry problem BMW compact.
    By al89 in forum 1999 - 2006 (E46)
    Last Post: 12-16-2006, 07:08 PM
  5. ///E46 M3 Cab Keyless entry problem
    By roundel325i in forum 2001 - 2006 M3 (E46)
    Last Post: 09-09-2004, 02:34 PM
