Results 1 to 9 of 9
Thread: Running wires through the firewall (passenger side)
    Sep 2013
    Omaha, NE
    1995 E36 M3 Coupe
    I am attempting to run wires through my firewall for my gauges. Pulled up the fuse box (driver side) and checked out the clearance and there is no way that I will be able to fit what I need through that cluster of wires. So I checked out the passenger side like most people do. I pulled my glove box and pulled up the carpet and found where I would be running my wires, but I am curious as to how I should go about this. I have included some pictures for reference.
    https://i.imgur.com/Dh4mnte.jpg
    https://i.imgur.com/bUcFDdo.jpg
    https://i.imgur.com/OGUpH51.jpg
    So the grommet has a large wire and a smaller wire running through it. I figured that I could peel back where the wires first enter the grommet but that is a no go. Do you guys just cut the grommet a bit to make room? Just curious because I don't want to tear into it if I don't have to but I don't think I have a choice and I don't want to potentially open that spot up to the elements either.
    washington dc
    Avus Cosmos Calypso!
    you don't need to tear into it. Just stick wires through one by one. I taped a wire to an awl and stuck it through.
    Mar 2011
    Bellevue, WA
    Prelude-328-M3-4Runner
    Quote Originally Posted by scooper View Post
    This! It is incredibly easy to get wires through there, just push them through and don't lose any sleep. I taped to mine to a clothes hanger.
    CBlock
    Mar 2013
    Upstate NY
    M3
    That little grommet holding the two wires (abs and side marker wires) has revisions for two more wires to be ran through. If you pop it off threw the engine compartment you'll see what I mean. Space is tight down there unless you've sawzalld the SAP pump brackets off.
    Feb 2002
    Orlando, FL
    Turbo 97 E36 M3, 99 M3
    Quote Originally Posted by cblockm3 View Post
    this! It is incredibly easy to get wires through there, just push them through and don't lose any sleep. i taped to mine to a clothes hanger.
    this^^^^^^
    1997 Arctic Silver/Black M3
    1999 Techno Violet/Dove M3
    Sep 2013
    Omaha, NE
    1995 E36 M3 Coupe
    Quote Originally Posted by Mklock View Post
    Saw that grommet but I think it might be too small for my gauge wires.
    Thanks for all of the replies. Wasn't sure if people were doing something different.
    NeilM is offline Member BMW E36 M3 Expert
    Fort Wayne, IN
    96 M3, 15 Golf R, 18 Q5
    I taped my wires to the blade of a Phillips head screwdriver and easily pushed it through. Unless you're trying to shove 00 welding cable through there the stock passenger side grommet will handle your needs.
    Neil
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    There should also be a grommet about 10-12mm diameter in the ECU compartment behind the ECU. Not used for anything, just plugs a hole through the firewall above the stack and behind the glovebox.
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
    Sep 2013
    Omaha, NE
    1995 E36 M3 Coupe
    Great, ran my lines through and what a pain it was. I've done several audio installs and never ran into a more difficult grommet to work with :/ Thanks for the help!
  1. Best place to run wire through the firewall?
    By MylesPH1 in forum 1976 - 1989 (E24)
    Last Post: 10-24-2015, 03:21 PM
  2. Running wires through the firewall
    By whiteghost1 in forum 1996 - 2003 (E39)
    Last Post: 02-15-2015, 02:02 PM
  3. Best way to run a wire through the firewall on the pass side
    By RSharma in forum 1995 - 2001 (E38)
    Last Post: 07-16-2013, 12:14 PM
  4. Need to run wires through firewall : how to?
    By RoadsterMike in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 04-19-2005, 12:10 AM
  5. running wire through firewall
    By black318i in forum 1991 - 1999 (E36)
    Last Post: 07-14-2003, 03:59 PM
