Results 1 to 16 of 16
Thread: Rear suspension, Bolt broke!
    May 2018
    Amsterdam (EU)
    325i '92, Polo 6R, XJ6S3
    Hi all,
    I don't know the English word for this bold, and part but its in the rear a d it broke. Luckily I was only on my drive way.
    Anyone know where to order upgraded bushings?
    Verstuurd vanaf mijn SM-G950F met Tapatalk
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    Most likely part # 33326771828 is the bushing, 33326863853 is the bolt, 33326760668 is the nut, 33326760363 is the washer.
    http://www.realoem.com/bmw/enUS/show...diagId=33_1004
    Oct 2003
    Seattle
    99 M3
    Rear suspension, Bold broke!
    M3?
    The early M3s had a rubber isolated lower BJ, later M3s run a solid UPR and LWR BJ p/n 33326775551.
    Possibly, non-‘M’s can run the same.
    328 Bearing p/n 33326771828
    1995M3 Bearing p/n 33326771828
    So, as far as I know E36 318/323/325/328 can run same Lower Control Arm Outer Bearing as late M3.
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    ^ Correct, i used m3 ball joints on my non M 325is. Much better than the rubber bushings.
    '94 325i Sedan, Arctic Gray: UUC LTW FW, EVO 3 and DSSR, +.020 Maxsil pistons, ASC delete, Eibach shocks/springs, 16" contour reps 238k
    '93 325is Coupe, Schwarz, work beater 299k
    '89 325i Vert, Alpine White: 5spd swapped. Sold
    '04 Toyota Sienna XLE Limited AWD, In progress swapping to M50/G250, http://www.wibimmers.com/board/index...nna-25i-build/
    '05 Volvo V70 R, 6mt, mostly stock, kid hauler 200k Sold
    '85 Toyota LandCruiser: Lifted, gas hog. 205k
    May 2018
    Amsterdam (EU)
    325i M-Tech rear lower lateral arm bushings
    Quote Originally Posted by jc43089 View Post
    Hi all, thanks for the replies, great!
    My BMW a: 325i M-Tech
    I have found this amazing set: https://www.schmiedmann.nl/nl/produc...duct=PFR5-4618 POWERFLEX -> near my area, i'll buy them and make sure to fit them with a friend.
    Thank you so much for helping so fast.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by magnetron View Post
    Hummmm…those look like E30/Z3/318ti/418ti(?) components.
    May 2018
    Amsterdam (EU)
    Quote Originally Posted by bluptgm3 View Post
    They confirmed my VIN number / order, so nothing to worry, thanks for the info tho.
    Oct 2003
    Seattle
    99 M3
    Ya don’t know about that, but those don’t look like E36 components.
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    The description says fits "E36E46X3 (E83)X3LCI (E83LCI)Z4 E85Z4 E86Z4 E89" which sounds right, those should all have a similar LCA design. If you look at adjustable aftermarket camber arms they typically show fitting all of those models with the same lower control arm. I would still use the M3 ball joint, all of the articulation and no squish. I have installed a couple on my non M and they work great. Also the OE ball joints are pretty cheap.
    Dec 2011
    Tallahassee, Florida
    1994 BMW 325i
    Hi all,
    Mileage that this happened?
    May 2018
    Amsterdam (EU)
    Ordered the original ones, as multiple people with trace experience told me to NOT change to poly bushes. For now, priority; Fix the issue and drive on the track again!
    May 2018
    Amsterdam (EU)
    Finally today I have fixed the issues of the bushings.
    Oct 2003
    Seattle
    99 M3
    …and got an alignment?
    May 2018
    Amsterdam (EU)
    …and got an alignment? Sent from my iPhone using Tapatalk
    Yes, forgot to photograph the front.. the screen is only rear. But 2.15 front camber.
    Oct 2003
    Seattle
    99 M3
    This might be of interest - note the total toe values.
    https://www.bimmerforums.com/forum/s...or-your-E36-M3
    May 2018
    Amsterdam (EU)
    thanks a lot!
  1. Help.. rear diff bolt broke, need generic replacement
    By erobinson in forum 1992 - 1999 M3 (E36)
    Last Post: 08-22-2011, 06:14 PM
  2. Rear suspension bolt
    By philip77o in forum 1991 - 1999 (E36)
    Last Post: 03-03-2010, 10:02 AM
  3. Rear camber bolt broke...
    By bimmerfiver in forum 1996 - 2003 (E39)
    Last Post: 12-02-2007, 11:43 AM
  4. What other BMW rear suspensions bolt on E30's?
    By LumberJackJim in forum 1983 - 1991 (E30)
    Last Post: 05-22-2005, 05:26 AM
  5. rear suspension broke
    By Yonkers320is in forum 1975 - 1983 (E21)
    Last Post: 04-17-2004, 05:43 AM
